Main > Software Forum
Playstation Emulator on Mame Cab?
wboy:
In answer to one of your questions, yes it works fine with the ArcadeVGA.
Set it to a res of 720x480 for an interlaced TV look.
You can set it to one the the AVGAs lower, no interlaced resolutions, but you'll have to use the registry to configure the X and Y res values accordingly, as the epsxe config utils only show typical PC resolutions to select from.
Least when I configured it 6 or so months ago with the current version of epsxe of the time, that was the case.
