Author Topic: Magnetism - Subwoofers / Hard drives  (Read 783 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: April 15, 2004, 12:25:14 pm »
While I know that computer speakers are magnetically shielded, how about subs?
I plan on using a sub in my cab, but don't want to fry a hard drive.
As an option, I'm thinking that a piece of MDF inserted between my mini-tower and my sub might do the trick.
Thoughts..............?
%$#@!&* machine took my quarter!
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re:Magnetism - Subwoofers / Hard drives
« Reply #1 on: April 15, 2004, 12:42:16 pm »
The magnatism is not the only thing that will mess a hard drive up, get a sub going pretty loud within a foot of a hard drive operating and you will fry the bearings quicker than the magnatism will destroy the data.
The noise Vibration might be worse than the magnatism.
Oldskool
« Reply #2 on: April 15, 2004, 02:05:20 pm »
I'm planning to isolate the mini-tower using some sort of vibration dampener. (foam or springs)
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
« Reply #3 on: April 15, 2004, 02:12:12 pm »
Get some sheet metal to attach to that mdf that you are laying in there.  That will help ensure no magentic forces can get to your HD
Oldskool
« Reply #4 on: April 15, 2004, 08:38:12 pm »
Really? Sheet metal?
How about rubber or another non-magnetizable material ?
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: April 15, 2004, 08:52:18 pm »
Rubber doesn't stop a magnetic field.
I'd guess a subwoofer is shielded too. Unless you can see the woofers themselves. If you want to be sure you should test for magnetic fields (or maybe it's in the manual)
Besides, the HD is embedded in a metal box. That will protect the HD from any magnetic field outside.
Apollo
    • Eight Bells
« Reply #6 on: April 15, 2004, 09:35:11 pm »
Invest in some chicken wire, that is better than solid metal.
hyiu
    • www
« Reply #7 on: April 15, 2004, 10:13:53 pm »
if you're using one of those computer speaker system, even with a woofer... I doubt they're strong enough to ruin a HD...
(even if you put them next to each other...)
unless you're putting like a 10+ in woofer right next to it...
even then... if you put the computer (with case...)
then it should still be ok...
but like previously said... if you have a EXTRA BIG woofer in there... and you like to turn it up and BOMB the whole place... The strong booming might actually shake the machine...
you'll need to have a speaker hole and might want to put some sound absorber around your computer....
