Main > Software Forum
FireFox/Mach3 Patch
ErikRuud:
I got another response back from Scott at boldtower.
He said: Looks like a link option -lflac is missing from the chdman link options your makefile. You may also need the -L<path to libflac.a> in there as well.
Well that was the problem.
I now have versions of MAME 0.79, NoNameMAME 079u4.05, DAPHNE 99.7 that should all be capable of running MACH3 and FireFox as soon as I acquire the proper videos.
Lilwolf:
I have only seen them on IRC (and a slow one at that) ages ago.
but watch the talk here... very similar to a rom request... (not that I wouldn't appreciate if someone happened to PM with a bit torrent link)
ErikRuud:
I was not asking.
I do have a non IRC source.
I need to solve my registry problems before I do anything else.
TheGatesofBill:
I just finished adding in the Megadriver stuff, I'll take a look at that now.
ErikRuud:
Did you see my previous post 4 posts back?
I got it working in 0.79u4.05.
The two stumbling blocks were the -Werror flag that is used in your makefile. I had to remove it. And the patch did not add the -lFLAC and -L references to the link for chdman.
I can send you the modified code if you want.
