May 07, 2024, 06:07:16 am
Here are some of mine:Centipede (Atari cab), particle board, w/ 19" monitor - 305lbsSinistar (Williams cab), plywood, w/ 19" monitor - 270lbsMad Planets (Gottleib cab), particle board, w/ 19" monitor - 330+lbs ??(estimate)
No way, you mean there is really only a 25 lb weight difference between an Atari cab and a Williams one? Man, it feels more like a 100 lb difference. ALthough the fact that Atari cabinets have nothing to hold onto might make them feel heavier.
Mine is only about 70 lbs with monitor. I decided to go with paper mache to make it. The best part is I can fill it up with candy and let the kids take a baseball bat to it once or twice a year.
So what would you suggest to make a cab out of if I want something strong but yet not "friggin" heavy? Also something that wont require 15 passes of sanding and priming just to paint it.Thanks
