Author Topic: Weight  (Read 1180 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Weight
« on: April 08, 2004, 01:26:45 pm »
I have a quick question...
1) What is your cabinet made out of?
2) How much does it weigh (indicate with or without monitor)
Just curious...
OSCAR
    • Oscar Controls
Re:Weight
« Reply #1 on: April 08, 2004, 02:37:36 pm »
Here are some of mine:
Centipede (Atari cab), particle board, w/ 19" monitor - 305lbs
Sinistar (Williams cab), plywood, w/ 19" monitor - 270lbs
Mad Planets (Gottleib cab), particle board, w/ 19" monitor - 330+lbs ??(estimate)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:Weight
« Reply #2 on: April 08, 2004, 03:31:51 pm »
My cab is made of 3/4" MDF with an internal frame.  I have never weighed it with or without the monitor, but to give you an idea, it is somewhere in the vicinity of "friggin' heavy."   :)
I would have to guess 375 lbs.
« Last Edit: April 08, 2004, 03:32:47 pm by Santoro »
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
Re:Weight
« Reply #3 on: April 08, 2004, 05:04:15 pm »
Mine would be the same as santoro's.  friggin heavy, I can move it around the floor ok (it has castors), but I wouldn't want to haul it up stairs or anything.
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re:Weight
« Reply #4 on: April 08, 2004, 05:28:23 pm »
My cabs are a cool 408 lbs made out of Birch plywood but with castors on them they move real easy.
I only know the weight since the first of my 2 cabs I shipped to my brother in the UK from the USA. I had guessed the weight at 400 lbs so I wasn't far off!
Gary
SNAAAKE
  • -Banned-
Re:Weight
« Reply #5 on: April 08, 2004, 06:05:26 pm »
Bottom with MDF and top with birch plywood.Atleast around 350lbs with monitor(guessing of course).
paigeoliver
  • Awesome face!
Re:Weight
« Reply #6 on: April 08, 2004, 07:04:27 pm »
No way, you mean there is really only a 25 lb weight difference between an Atari cab and a Williams one? Man, it feels more like a 100 lb difference. ALthough the fact that Atari cabinets have nothing to hold onto might make them feel heavier.
shmokes
  • Don't tread on me.
    • Jake Moses
Re:Weight
« Reply #7 on: April 08, 2004, 07:17:49 pm »
Mine is only about 70 lbs with monitor.  I decided to go with paper mache to make it.  The best part is I can fill it up with candy and let the kids take a baseball bat to it once or twice a year.
Best Kid iPad Apps
OSCAR
    • Oscar Controls
Re:Weight
« Reply #8 on: April 08, 2004, 08:39:35 pm »
No kidding, check it out yourself:
http://www.arcadeflyers.com/?page=flyerdb&subpage=flyer&id=158&image=2
http://www.arcadeflyers.com/?page=flyerdb&subpage=flyer&id=190&image=2
I agree that it is deceiving, Atari cabs seem to feel a lot heavier for some reason but they really aren't that much heavier than most of the others (except Nintendo!).  :)
paigeoliver
  • Awesome face!
Re:Weight
« Reply #9 on: April 08, 2004, 08:42:15 pm »
My Space Firebird actually weighed in at under 100 lbs, with everything inside. I was so light and easy to move that my buddy an I were able to covertly move it from the end of the second row to the beginning of the first row at the auction while they were selling the slots.
chrisindfw
  • I drank what?
Re:Weight
« Reply #10 on: April 09, 2004, 02:09:47 pm »
So what would you suggest to make a cab out of if I want something strong but yet not "friggin" heavy? Also something that wont require 15 passes of sanding and priming just to paint it.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
Re:Weight
« Reply #11 on: April 09, 2004, 02:15:04 pm »
Aluminium, but that would be expensive.
Santoro
  • Santoro
    • ArcadeReplay!
Re:Weight
« Reply #12 on: April 09, 2004, 02:19:43 pm »
To avoid weight, my next cab will probably have plywood sides, 1/2" MDF front & top, and Masonite back panels.  I am still debating frame vs no frame.  No frame is obviously lighter.
paigeoliver
  • Awesome face!
Re:Weight
« Reply #13 on: April 09, 2004, 04:18:41 pm »
Plywood, and don't paint it, stain it.
Xiaou2
  • NOM NOM NOM
Re:Weight
« Reply #14 on: April 10, 2004, 04:43:01 pm »
 heh!  interesting lightweight idea...
  make the internal frame suppoorts with 1*1's or PVC or thin metal tubes.. ect.
 then cover the frame with cloth  or  cardboard, paperboard...ect.
 since its not going in an arcade where you have to worry about someone cutting the outsides and stealing the components... it should be fine.
