Main > Main Forum
Weird problem with IPAC: can
Lilwolf:
unplug the controls from the joystick to the ipac.
Then cross them by hand...
I'm guessing its the wiring... but there isn't much you can do..
With microswitchs.. if you take the NO from one microswitch into the ground of the next... it works but you can't do more then one at a time. I don't know if 360's can do this (never used one)
good luck
Tiger-Heli:
--- Quote from: Lilwolf on April 05, 2004, 01:26:33 pm ---I'm guessing its the wiring... but there isn't much you can do..
If it works when the I-PAC is set to one key, but doesn't work when the I-PAC is set to the arrow keys, it's not the wiring.
Things to try -
Just out of curiosity - if you program the joystick to UP, Right, Down, and Left, diagonals don't work, but YNGJ does - What if you program it to Up,J,Down,N (Curious if it's a buffer problem with all the arrow keys, or something different).
Program the I-PAC to the arrow keys and get Ghostkey or KeyHook from http://www.arcadecontrols.com/arcade_downloads.shtml#Utilities Move the joystick and see if the diagonals register - If yes, the I-PAC is working, but the I-PAC software isn't picking up the keypresses. If no, then the I-PAC is not sending the proper keypresses to any program.
Fat-Johnny:
--- Quote from: Tiger-Heli on April 05, 2004, 02:16:23 pm ---Program the I-PAC to the arrow keys and get Ghostkey or KeyHook
I started out and tried to play SmashTV. The diiagonals are working great!! I can run in bothclockwise circles and counterclockwise circles. I then wentr immediately back to WinIPAC, and still no diagonals are registering.
I then downloaded and tried Ghostkey. Diagonals look great. Back to WinIPAC, still funky.
I downloaded Keyhook. This proggy only registers one key at a time.
I downloaded something else from our download page called Virtua Keyboard. Displays a keyboard on screen and highlights what is being pressed. Diagonals work great. Back to WinIPAC, still funky.
Guess my IPAC and joy works OK after all. I guess its a little bug with the new WinIPAC software. I'll probably e-mail Andy and let him know.
Thanks for the help Tiger,
FJ
Tiger-Heli:
--- Quote from: Fat-Johnny on April 05, 2004, 04:59:38 pm ---Thanks for the help Tiger,
FJ
No Problem, glad it worked out!
Thenasty:
glad you got it to work. I thought we a missing the obvious that maybe the actuator is reverse on the p360.
