Author Topic: Did I buy the wrong wire for my control panel?  (Read 915 times)
Xynie
  • Last login:July 13, 2020, 09:30:19 am
  • Sometimes, I feel like Dilbert.
« on: March 26, 2004, 09:32:59 pm »
Heya...  I bought some 18g wire from Radio Shack from my control panel, but I didn't notice it is "solid" wire.  It is a little stiff, but usable.  Can I use this wire for my control panel or should I go find something else?  What kind do I actually need if it's the wrong one?
The wire I got is...
15 Ft Rolls
Rated 300 Volts
18 Gauge
Solid
80 Celcius
1/64 PVC
So...  did I buy the wrong stuff?
Anthony
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
Re:Did I buy the wrong wire for my control panel?
« Reply #1 on: March 26, 2004, 09:34:55 pm »
It should be just fine.
paigeoliver
  • Awesome face!
« Reply #2 on: March 26, 2004, 09:43:33 pm »
Solid wire IS more likely to break, and 20 gauge stranded is actually the standar wire to use for controls.
BUT, it should be fine as long as you are not doing swappable panels, or anything else that would involve the wire getting moved around a lot.
MUKid
  • Last login:March 31, 2004, 12:23:35 am
  • Hoody Hoo!
« Reply #3 on: March 27, 2004, 01:34:13 am »
There are two problems with solid wire.  First, it's really stiff and hard to work with, especially compared with stranded wire.  More importantly, it's too thick to fit into the quick-disconnects if you are daisy-chaining for the ground loop.  One wire will fit, but two will not.  At least, that's my experience.  I'd return it and get stranded wire.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: March 27, 2004, 02:23:34 am »
I built my first control panel with some really stiff wire.  It is stiff enough that if I bent it back and forth a bunch of times it breaks.  It was seriously awful.  It worked, but not very well, and over time while I would monkey with it, parts would break.  Since then I bought some softer wire, and it's heavenly.  I can bend it back and forth 'till the cows come home and it won't break on me.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #5 on: March 27, 2004, 09:25:04 am »
Solid core wire also offers more resistance. I believe Andy recommends stranded wire for this reason as well. I've heard of quite a few people around here that use solid core wire with no problems, but it's possible (however unlikely) that you could run into electronic anomalies.
If you build a frankenpanel, chances are I don't care for you as a person.
Xynie
« Reply #6 on: March 27, 2004, 09:51:50 am »
I'm goin to buy some stranded this morning... thanks for the advice guys :)
