Author Topic: BYO "Nasty-Spinner" UPDATE....  (Read 47209 times)
Thenasty
  • Last login:Yesterday at 10:21:15 pm
« on: March 25, 2004, 05:25:23 pm »
Here is a write up of how to build one of this.
UPDATE: Now w/Quick Bunny Spinner TOP.
See below for the top of the Spinner Tops.
If you want one PM me and I can make one for you for
$18.00 Shipped in USA.
If you want to build your own "All in One Ultimate Coin Mech" here is the link.
http://forum.arcadecontrols.com/index.php/topic,19200.0.html
Add Diagonal joystick support for Q-bert/Congo Bongo to your Happs 360 Joystcik. Here is the link for the mod.
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=25385
« Last Edit: September 03, 2020, 09:57:01 am by Thenasty »
Free VGA Breakout Cable
Thenasty
Here are the tools you need..
« Reply #1 on: March 25, 2004, 05:32:36 pm »
Here are the tools used:
A. Torx #8
B. Torx #6
C. 6/32 Threader (use to made thread under the spinner).
D. 3/16 wrench
E. Phillip Screwdriver
F. Flathead Screwdriver
G. Long Nose Plier
H. Dremel
Thenasty
Parts needed
« Reply #2 on: March 25, 2004, 05:38:33 pm »
this are the parts needed
A. Mouse (PS2 or Serial) I think USB are all optical.
B. "L" Bracket (dollar store)
C. This nuts are from the Video Card, Sound card, etc..
D. This nut came the Computer Case you bought before.
E. This Shrink Wrap.
Misc Items not listed:
1. Epoxy
2. Blow Dryer (for the shrink wrapper)
Thenasty
YOu need to find a Western Digital Hard Drive
« Reply #3 on: March 25, 2004, 05:41:49 pm »
Now you need to get one of this Western Digital Hard Drives. And open it up using the TORX #8 and #6. So you should have this.
Thenasty
Get those nuts that came from the Video Card, Sound card, etc..
« Reply #4 on: March 25, 2004, 05:46:19 pm »
Now time to cut this a little shorter to make the a shaft.
Using the Dremel (carefull with this) and cut off about 1/2 of the thread.
« Last Edit: March 25, 2004, 06:15:29 pm by Thenasty »
Thenasty
After Cutting this...
« Reply #5 on: March 25, 2004, 05:56:16 pm »
After cutting 4 of this, take attach them to each other using the 3/16 wrench and put some Epoxy to make it better grip.
Now after that step, take the swrink wrapper and wrap aaround the nuts about  3 1/2 piece (not all 4 nuts) and heat it up using a blow dryer (make sure its hot).
Now use the 6/32 THREADER and thread the bottom of the SPINNER so we can screw the  Letter D -  This nut came the Computer Case you bought before.
And this is how it is ....
A. is the 4 nuts thats been cut and shrink wrap.
B. this is screwed in there using the 6/32 THREADER using the GOLDEN nut from the computer case.
« Last Edit: March 25, 2004, 06:13:40 pm by Thenasty »
Thenasty
Finish the mouse part.
« Reply #6 on: March 25, 2004, 06:06:37 pm »
Now you need to cut the PLATTER disk from the Hard Drive and drill 4 holes on the sides.
using the Hack saw......
Cut the "L" to make one end shorter.
Glue the "L" into the CUT Disk Platter.
Put the Platter pieces together.
Hack the mouse and cut the housing of the mouse (hacksaw).
Glue the mouse into the "L".
Glue the WHEEL into the GOLD NUT that was screwed  on the bottom of the SPINNER.
Your Done. ! ! ! !
Use more of the Silver nut that came from the Video Card, Sound card etc... to make adjustments of the SPINNER TOP.
« Last Edit: March 25, 2004, 07:39:03 pm by Thenasty »
Thenasty
Re:BUILD YOUR OWN "Nasty-Spinner".
« Reply #7 on: March 25, 2004, 06:19:04 pm »
There are tons of write up on MOUSE hack thats why its not included.
And here is what it should look like....
Thenasty
The End
« Reply #8 on: March 25, 2004, 07:18:55 pm »
I'll build SERIAL or PS2.
Building one for you it all depends on availability for the parts. If get all the parts needed (Hard drive specially), I can build it for you right away.
UPDATE: A Quick Bunny Spinner TOP will be included. look below to see how it looks. Thanks
« Last Edit: March 30, 2004, 09:17:25 am by Thenasty »
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #9 on: March 25, 2004, 10:38:55 pm »
I'm missing something here.  Where is the green spinner knob from?  I re-read this carefully, but I fear I'm now looking SO hard that it's blinding me to the obvious.  Please point me in the right direction, as I would like the option to have a knob to match my CP, and it seems like that could be accomplished by the manufacturer of that knob.
Thenasty
« Reply #10 on: March 25, 2004, 10:51:39 pm »
UPDATE: I am now building a "Quick Bunny Top" for this Spinner. This is your temporary or permannet TOP untill you decide to buy one and replace it. You might not even want to replace it once you try it.
« Last Edit: March 30, 2004, 09:18:37 am by Thenasty »
rdagger
« Reply #11 on: March 25, 2004, 11:12:53 pm »
that green know is from SlikStik. THe other one is an Arkanoid.
It's a nice knob.
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #12 on: March 26, 2004, 12:42:24 am »
You might want to super glue some big washers to the bottom of the spinner to act as a flywheel, otherwise the spinning action is too light.
http://www.doughansen.net/arcade/spinner.htm
« Last Edit: March 26, 2004, 12:46:02 am by dhansen »
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
Re:Parts needed
« Reply #13 on: March 29, 2004, 09:41:41 am »
Just picked up a brand new USB mouse for $3cdn and it's not optical.
So if you're looking for one, they're out there.
ps. love the plans, as you can tell, I've already started on it.   ;D
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:BUILD YOUR OWN "Nasty-Spinner" now w/Bunny Spinner TOP
« Reply #14 on: April 02, 2004, 01:55:01 am »
someone drinks alot of chocolate milk, huh?
crashwg
« Reply #15 on: April 02, 2004, 06:15:23 am »
How do you get the quick cap to atatch to the spinner?  Do you fill the cap with something?
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Thenasty
« Reply #16 on: April 02, 2004, 08:41:15 am »
Hehe  ;D
Good thing I got kids to help me out. I feel likea Wabbit "Silly Wabbit, tricks are for kids".
Thenasty
Here is how to BYO Bunny Spinner Top.
Tools Needed
A. Quik Milk Chocolate (Drink it while making one of this)
B. Drawer Knob
C. 3/8 Nut
D. 3/8 Set Screw
E. 3/8 DIE
F. Final Piece what it looks like (Epoxy in the inside)
G. Final Finish product filled w/Bondo (not pictured)
H. Allan-Wrench
Misc not pictured.
Drill w/Drill Bits
3/8 Tap (See pic at bottom).
« Last Edit: April 02, 2004, 02:43:28 pm by Thenasty »
Thenasty
First take the Drawer Knob and 3/8 die and make a 3/8 thread.
Then Take the 3/8 Nut and screw it in.
Then Take 3/8 Drill Bit and make a hole in the 3/8 Nut (see pic)
While your at it, make the hole bigger in the center of the  Drawer knob until you get a size of 1/4 (this is for the shaft).
« Last Edit: April 02, 2004, 02:44:58 pm by Thenasty »
Thenasty
Then take you 3/8 Tap and make a thread inside the NUT.
Once Thread is made, screw in the 3/8 Set Screw w/Allan wrench.
Thenasty
Last drill a HOLE on the side of the Bunny TOP for the Alan wrench so you can screw the SET Screw when the Spinner Shaft is installed.
Glue (Epoxy) the Drawer Knob inside the Bunny Top and let dry, then fill it w/Bondo for weight.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
good writeup but man, focus your camera =p
"Owens is the ringleader in the ass hat circus"  D K
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
I recently tore up a hard drive to get the bearing in the middle, was contemplating some options
One of the write-ups I saw had some elaborate combination of rods and washers and glue and stuff to make the threaded piece that fits the knob and attaches to the spinner guts
What I found that worked REAL good was one of the finger-tighteners from a monitor cable. On the plug end youve got your 15pin d-sub connecter and 2 posts on either side that thread into the hex's on the video card. The threading was exactly right for the center of the bearing, and the plastic knob part was perfect to slide the knob over
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
FYI, I tore apart a Maxtor HD and it did not work. Forget the model # at home.
This idea has got me thinking...I am working on finding parts to fit a threaded rod. It seems like that would be a little beefier and stronger. You could also use bigger bearings. Home Depot had rods in 1/4" and all other diameters.
My kids are going to be using the cab and I have to make it as kid-proof as possible.
I am also trying to find parts that are available to everyone.
Did not have much luck the other night at Home Depot...the quest continues...
Half of the people you meet are below average.
ErikRuud
BobbyG66,
I made my spinner using parts that I got at Ace Hardware.  I used a 6" long 1/4" carriage bolt.  It was cheaper than the threaded rod.
All of the hard are in these pictures came from Ace hardware.
1 6"long 1/4" carriage bolt (head cut off).
2 flanged ball bearings.
2 bronze sleeve bearings (to reduce the 3/8" hole in the ball bearings to 1/4")
4 large fender washers for fly wheel
4 nuts to fit carriage bolt
1 Black knob with set screw.
I might have to look into the Bunny Knob, I like how quirky it is!
American Laser Games Wrapper
O2em Rom Utility
BobbyG66
Yep, that's what I was thinking.
Just got to find the bearings now. With good bearings and a good size flywheel, it should spin nicely.
Thanks guys.
ErikRuud
Ace has a nice selection of bearings.  They had realy nice sealed ones, but they were about $18.00 each.  I went with the much cheaper ones that were not sealed.  They were heavily packed with grease, but a few shots of a spray silicone lubricant cleaned them up nicely.  The spin eally smoth too.
O2em Rom Utility
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
BobbyG66,
What about the encoder wheel? Did you make it or buy it?
HagHore
  • Last login:October 24, 2007, 02:24:00 pm
  • Game Over Man, Game Over!
Just thought I would post on theNasty's spinners as I had him whip me up a couple.  Plugged one into the serial port of the PC I'll be using in a planned cab (DOS 6.22 and DOS MAME v36 or v53) and played some Arkanoid, Championship Sprint and a couple of others.  After adjusting the speed/sensitivity the spinners work just fine.  Used the Q-Bunny tops he made and they are certainly different and will lend a unique appeal to your cab, however, they are just a tad lopsided, nothing that affects gameplay at all and not noticeable unless you just sit there and stare at your spinner while twirling it back and forth  ;)
All in all, I give 'em a thumbs up and well worth the money, especially since I didn't have to spend the time scrounging for the parts and putting 'em together.  Thanks again theNasty!
We're on an express elevator to Hell! Goin' down!
ErikRuud
The encoder was hand made.
I printed out the encoder wheel from the Cheep Spinner instructions and glued it to a sheet of thin styrene plastic using a spray adhesive.  Then I cut the outer cirle using a pair of scisoors.  I cut the teeth by hand using an Exacto knife. Drill a hole in the center and your done.
O2em Rom Utility
albarellij
  • Last login:October 24, 2018, 09:31:29 am
Ok, long-time lurker here...great thread.  I want to build my own spinner like this, I have the hard drive and some of the other hardware, my question is, where the HECK do you find a #6 and #8 Torx  drivers?  I've looked everywhere...Home Depot, Lowes, Radio Shack, local Hobby Stores...am I missing somewhere?  Thanks for any help, and thank you all for making this place a fantastic resource.
Thenasty
Radio Shack should have them Bring your HD with you when you go so you can test it right there. I bought mine in a Electronic Shop.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Can you provide details of the pcb bit of you spinner (assume it is a optical detector of some sort) ?
i have an ultimarc opti-pac would it connect to it directly? or would some extra electronics be required.
HagHore
Got my Torx drivers at Sears.
Oh yeah, Nannuu & I also finally got around to installing Nasty's spinner.   Replaced the bunny knob with the knob that Bob Roberts sells, and it works really well.  Only problem was the L bracket came unglued so it had to be re-epoxied on.
« Last Edit: May 08, 2004, 10:21:42 pm by HagHore »
Ed ONeill
  • Last login:April 12, 2012, 10:00:16 am
    • http://home.comcast.net/~coin-opcollector/
Re:BUILD YOUR OWN "Nasty-Spinner" and BUILD YOUR OWN Bunny Spinner TOP..
« Reply #34 on: June 21, 2004, 12:22:42 pm »
Can anyone answer these questions?
How much space do I need under the control panel?
Can the rod above the plate be cut down or made smaller?
Ed
Always buying Gumball/candy machines and parts email - coin-opcollector@comcast.net
Want list - Diner Pinball, hit the ice cab, tmnt controls and panel
independentthread
  • Last login:March 01, 2005, 07:16:10 pm
Re:YOu need to find a Western Digital Hard Drive
« Reply #35 on: June 28, 2004, 01:38:23 am »
I caught this link from another thread, and I've gotta say: That is by far, the BEST use for an old hard drive that I've ever seen.  And who knew that electronics were compatible with chocolate milk!?  This project is so unique that you deserve a patent!!!
The default personal text is is "I'm a llama!"???  I guess that makes me an emperor with a new a groove.
sfetaz
  • Last login:March 11, 2008, 12:58:28 pm
  • DDR4LIFE
    • Home of DDR Machine Rentals and The Madison Square Garden DDR Championships!
« Reply #36 on: July 15, 2004, 08:13:58 am »
Hey Nasty can you still build me a spinner?  Haven't heard from you in email in a while.  Please let me know.  Thanks  :)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #37 on: August 16, 2004, 12:45:45 pm »
Bump for another spinner-wanter...
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« Reply #38 on: September 28, 2004, 02:19:56 pm »
Does the hard drive have to be a Western Digital?  Or can any old hard drive work (I have an old Maxtor I beleive)?
melarky
« Reply #39 on: September 28, 2004, 02:20:59 pm »
actually, it may be a seagate now that I think about it.  At any rate, will any old hard drive work?
