Author Topic: X-Arcade controller not "clicking"  (Read 841 times)
MameMe
  • Last login:June 08, 2005, 06:45:25 am
« on: March 23, 2004, 01:38:00 pm »
I just received my x-arcade solo and I notice that I have to press extremely hard in the upwards direction to hear the "click".  Therefore pressing up normally on the controller does not work, I have to really yank it up to get it to work.
Is there something I could "adjust" inside the controller, for example move the UP-Switch closer to the controller shaft?   ;D I said shaft.
Serioualy though I could use some ideas here.
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
Re:X-Arcade controller not "clicking"
« Reply #1 on: March 23, 2004, 02:04:27 pm »
My joysticks are x-arcade replacements, when i used them as they was suppose to i also found i had to press up really hard to get a click, so i bent the pins on the microswitches so there closer to the center
MameMe
« Reply #2 on: March 23, 2004, 02:21:31 pm »
Eww :-\  Hopefully it doesn't come to that, but I guess if thats the only way then that's what I'll have to do.
Zakk
  • Last login:Yesterday at 10:05:51 pm
« Reply #3 on: March 23, 2004, 03:45:55 pm »
I think the instructions even say to open up the back and adjust the pins.  There's a picture with the back open here:
http://www.mameworld.net/massive/Cabinet/Project_X/project_x.html
Just bend it with needle nosed pliers, there's only about 6 or eight little screws holding the bottom on.  Good luck!
MameMe
« Reply #4 on: March 23, 2004, 06:07:01 pm »
Well I bent the pins as suggested and although I'm not impressed with this solutions it does work.
Thanks everyone
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« Reply #5 on: March 25, 2004, 03:55:54 am »
Thanks everyone
Fear not grasshopper :) Worst case scenario you can always buy a new switch if something would break.  Switches are pretty cheap. Couple'a bucks.
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
