Main > Main Forum
Help! Anyone here got original Centipede upright?
1UP:
--- Quote ---1-upyeah we need a database like that badly. I did post a while back on the collector's newsgroup but did not get much of a response.
Yeah,
Carsten Carlos:
Thanx again, just updated my homepage with your new measures -well, with most of them, I've to add something to my drawing to add the rest of them, which are also very helpful!
How are you satisfied with the controlpanel-height? Many cabs have it to low for me, but maybe I'm just a tall person. I'll think about if I just add rolls at the bottom of the cab, this would make it approximately 6cm/ 2,5" higher.
--- Quote ---i recommend using 1'' quarter round on the top front corner of the control panel to approximate the bent in the original metal panel.
Good idea, I always wondered how to make this, as I want to make the switchable controlpanels with a front included, e.g. to make a panel which supports flipper-buttons in front.
larry smith:
The height is ok for me, i'm 5'8'' but it could be higher
I think the classics had the CP's a little lower than todays games.
the way my panels swap the front including the curve is fixed, the top clamps from below and the bottom folds down to allow access to the clamps and to act as a keyboard shelf. The advantage is that the swappable part is easy to make.
)p(:
--- Quote ---
Yeah,
1UP:
Looks cool!
