Main > Main Forum
suzo Happ 3 inch trackball Only goes Left to Right
Tumuchfun8487:
Thank you for the Help.
Picked up a better multimeter and confirmed all inputs and outputs to be within range. Dialed up the power to get 5 volts vs the 4.10 I was getting. I adjusted the ground contacts in the track ball to make a clean contact with the rollers and appears to be working.
I was hoping the accuracy would of been better when using the trackball but after reading some reviews that are people that said it's normal.
Navigation
[0] Message Index
[*] Previous page
Go to full version
