Author Topic: Neutral gear in Cruis'n USA  (Read 1740 times)
Endprodukt
  • Last login:Today at 03:27:36 am
« on: July 02, 2025, 04:05:26 pm »
I was wondering if you guys have a solution to get the neutral gear to work? It expects a dual input on one gear to shift to neutral. I would like it to behave correctly if anyone has a solution.
SailorSat
  • Last login:Yesterday at 07:15:58 pm
    • For Amusement Only e.V.
Re: Neutral gear in Cruis'n USA
« Reply #1 on: July 03, 2025, 12:54:37 am »
I don't understand the question in the first place.
Do indeed switch to neutral by tapping one of the 4 gear inputs twice.
On a real shifter, I'd move the stick to 1, then pull it slightly back (to have the microswitch in the shifter open) then have it snap back to 1st - you're in neutral now.
You want it to switch to neutral if moving the shifter into neutral position?
Endprodukt
« Reply #2 on: July 03, 2025, 02:56:20 am »
That would be the expected behavior. No gear engaged = neutral.
It's a bit weird what mame does.
Good to see you around btw
SailorSat
« Reply #3 on: July 03, 2025, 07:38:00 am »
Just checked the MAME source - yes, kinda crap what they did there.
Nothing you can do though. I'll send in a patch to MAME.
Endprodukt
« Reply #4 on: July 03, 2025, 08:03:06 am »
Thank you very very much. Glad to hear I wasn't stupid. I will check if the other midway racers behave the same.
Endprodukt
« Reply #5 on: July 03, 2025, 11:50:51 am »
Cruis'n World and Offroad Challenge act exactly the same.
San Fracisco Rush can't even set to neutral and has no button assigned in mame.
SailorSat
« Reply #6 on: July 03, 2025, 03:03:40 pm »
Cruis'n World and Offroad Challange are the same driver as Cruis'n USA after all :)
Currently wondering on how to approach the issue in the first place.
The current system probably was made so you don't have to constantly "hold" the gear button (like a real shifter would).
Endprodukt
« Reply #7 on: July 04, 2025, 05:14:26 am »
Model2 emulator has a hold gear option for that. Not sure mame would allow something like that.
  • Last login:July 14, 2025, 01:30:54 pm
« Reply #8 on: July 04, 2025, 11:29:45 am »
Been out of the loop for a long time, but a solution was added to disable the toggle behavior on the Hi/Lo shifter games.
I do not know if it works in Cruis'n.
https://forum.arcadecontrols.com/index.php/topic,135345.msg1397466.html#msg1397466
Endprodukt
« Reply #9 on: July 09, 2025, 06:14:29 am »
It doesn't unfortunately. Actually mame will delete the flag from the cfg after running the game.
Fursphere
  • Last login:July 12, 2025, 03:05:16 pm
« Reply #10 on: July 09, 2025, 09:37:39 am »
What are you using as a shifter?   If its a joystick, you could probably use a AHK macro to minic the required key presses in MAME.
Might be able to use joystick gremlin to insert key presses as well.  (in gear = gear # button) (out of gear = neutral button) type of thing
https://whitemagic.github.io/JoystickGremlin/
Endprodukt
« Reply #11 on: July 10, 2025, 08:14:08 am »
Yeah that has been suggested by gpt. Tried AHK as well. Sure there is workarounds but I was hoping there is a straight mame solution.
