Author Topic: Modular controls panel discussion  (Read 8708 times)
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« on: March 08, 2004, 04:59:05 pm »
Looking through the old posts, I know there's a handful out there.  Who's got 'em?  How're you attaching them?  What are the different layouts you're using on your modular pieces and the panel as a whole?
My cabinet is started (though on hold, as I build a 4-player cab for a friend) and I'm at the point where I need to really finalize my CP plans.  I've planned to go modular all along as I want the CP contained within the sides of the cabinet for that old-school aesthetic, yet I'd still like to be able to play 2-Player and controller specific stuff without it being a jumbled mess.
I'm thinking that some sorta 1/2 turn Dzus type fastener may be the way I attach things.  Should give a good solid mount.  Just gotta figure out what the mounting requirements for them are.  I've never used them on anything other than thin panels like a motorcycle body panel.
So far, my planned pieces will include:
  • 4  x  4/8 Way sticks
  • 2  x  7 button groups    (Probably will change the layout from the one pictured below)
  • 2  x  trackballs  (likely 2 1/4")
  • 2  x  Track & Field 3-button groupings
  • 1  x  Tron style trigger stick
  • 1  x  Spinner  (This may actually become 2 spinners)
  • 4  x  2" spacers
  • 2  x  1" spacers
Possible other modules could include button specific layouts for games such as Defender, Asteroids, etc.   Though I could get away with using the Tron type stick & a regular one, I may go with a matching trigger stick for Battlezone.
Here's a quick 3-D rendering of some layouts possible with the above listed modules.  Total panel width is 30" with the room for the modules being 26" wide.  This may seem a little tight, but I never had trouble playing 2-Player games next to someone at the arcade in the 80's.  Though I'm not quite the same size I was in the 80's, I suppose. :)   I'm gonna lay this out on foam board tonite, if needed I can go a little wider for the modules.
From top to bottom:
  • 2-player general
  • 2-player trackball
  • Robotron
  • Track & Field - Centered spinner
  • Normal 1-Player mode (would be left this way most of the time.)
If you can't be a good example at least try to be a horrible reminder.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
Re:Modular controls panel discussion
« Reply #1 on: March 08, 2004, 05:49:37 pm »
My biggest concern for you is have you really thought about what games you intend to support on you machine and what is needed for those games. For example you have one with 2 trackballs, there are only a few games that use 2 trackballs at the same time. Also one would really like track and field to have a dedicated cp for that type of game when you'll probably fine one of your other buttons might work out just fine.
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #2 on: March 08, 2004, 06:01:32 pm »
It looks pretty good.  Having 2 tballs is good.  The point of modular control panels is to support as many games as possible without having a frankenpanel.
DougHillman
« Reply #3 on: March 08, 2004, 06:33:19 pm »
Marble Madness dude!  No other reason to build a 2 trac panel, but more than enough incentive to. :)
You obviously didn't grow in the 80's or at least didn't spend much time in arcades playing "Track & Field."  If I don't have the space to place my left hand between the buttons and use one of these
(colored red of course) as a lever so I can run faster, it ain't "Track & Field."
As has already been said, you make modular panels so that you can have more arcade realistic control setups without using a crapload of space and making the thing look beastly.  (IMNSHO)
{Please note that the colors & stuff of the modular panel peices in the rendering are only there to differentiate one from the other while I'm arranging things.  The final product will be covered with vinyl or lexan with a CPO.)
D
« Last Edit: March 08, 2004, 06:35:18 pm by DougHillman »
Tilzs
  • Neat
    • Cocktail Arcade
« Reply #4 on: March 08, 2004, 06:43:12 pm »
Well you can do what you want. I was in the 80's and know the pencil trick in tnf. The point I was trying to make was to make sure you thought about your cps before you put them all together. I've seen a bunch of people put buttons on things just for the sake of putting buttons. You it seems have thought about it.
NoOne=NBA=
« Reply #5 on: March 08, 2004, 08:07:11 pm »
I'm still working on mine at the moment.
I opted for a little simpler approach than the one you are planning.
I layed out all my "must-have" panels, and started going nuts with the spacers etc...
I then started simplifying, and decided that I could do everything I wanted without a huge number of spacers.
My CP area is exactly 24" wide.
Using that area, I decided that I could do most of the modules 6" wide.
The trackball modules, one T-stik plus module and the Tron stick modules will be 12" wide.
That will let me do just about every game I can think of near-perfectly.
The modules necessary for it are:
(2) 2-button (Asteroids left side)
(2) 4-button (Asteroids right side/Star Trek buttons)
(1) 4-button diamond layout (Vanguard)
(2) T-stick Pluses (on 6" modules)
(1) T-stick Plus (on a 12" module to center perfectly for games like Pac-man/Donkey Kong)
(2) Top-fire Happs (needed for tank games, etc...)
(1) Repro Defender Stick w/Reverse Button (Can't do Defender justice without it)
(2) Tron Sticks (need two for games like Vindicators/Sarge)
(1) DOT Spinner
(1) Model 3 Spinner (need two spinners for Blasteroids)
(2) Trackballs
(2) 6" Spacers
I don't play fighters, but (2) 7-button panels would cover that as well.
As far as how I'm mounting them, I'm using Connecting Bolts to screwed into T-nuts to hold the modules down.
The screws have an allen-wrench head on them, and I bought a bit for my cordless screwdriver to make the swapover faster.
I'll post some pics after I get it to a more finished state.
Valence
  • Last login:June 15, 2004, 10:44:49 pm
« Reply #6 on: March 08, 2004, 11:36:38 pm »
Here is my
Project
thats modular
I use an L bracket in the front that slides in to hold them down.
I need something still for the back but I found these pushbutton lock that are almost flush.
paigeoliver
  • Awesome face!
« Reply #7 on: March 09, 2004, 06:21:26 am »
Ok, I am going modular on my latest project.
Also, quick suggestion about yr track and field/spinner panel. I would suggest changing it to a dual 5 button layout to properly support Space Duel, and other 2 player vectors (also the dual 5 button layout would nicely support Stepmania in Pump mode).
I currently only have ONE panel completed (which is keyboard hack for now), but I am going to move over to a JAMMA fingerboard system for all of them. All panels are stock Defender sized panels, and are attached in the standard manner for a Defender.
Here are the for sure panels.
Defender panel. Completed. Slightly non-original. Has NOS Willis brand Defender overlay, very nice (but technically incorrect) 2-way, and all NOS illuminated leaf switch buttons.
Tac/Scan (Spinner) panel. I have FINALLY managed to get the darned spinner off the stupid panel it was on (only took me 8 months). I am going to attempt to remove the overlay as well so I can reuse it. Even without applying any heat it seems like it is going to peel off pretty easy, so I should be able to salvage it undamaged using a blowdrier.
2 player panel. Standard 2 player 6 button layout. Going to use half of my Road Fighter overlay for it (overlay is large enough to cover 2 panels). I may or may not use Wico sticks on this one. I prefer them, but I am out of them, and NOS ones have been getting harder and hard to find. I might just go with perfect 360s.
Trackball panel. Using my 3" Imperial PS2 trackball, and the other half of my Road Fighter overlay.
4-way panel. Using a Willis Q*Bert overlay and a used Q*Bert stick mounted in the standard manner, not in the Q*Bert manner. (at least I THINK it is a Q*Bert stick, it is 4-way, and its nonstandard center hole deally sure matches up with the overlay). I MIGHT possibly use a Happ's Universal in 4-way mode instead though, since those can easily be rotated 45 degrees for Q*Bert mode.
Asteroids panel. Using up another NOS Willis overlay for this one.
I am also mulling over a dual 49-way panel (I have a complete Arch Rivals panel that even fits my cabinet), a mechanical rotary panel (I have ONE, buy I am not sure if it actually works), a Baseball panel (I have a couple of those spring loaded analog baseball sticks), a 270 steering wheel panel, and a Stepmania panel.
I really want myself to care about Tron enough to do a Tron panel, but the fact is that I only played that game ONCE in the arcade, and maybe twice in Mame since then. It just doesn't grab me.
DougHillman
« Reply #8 on: March 09, 2004, 12:43:54 pm »
Paige, sounds more like you're going with swappable panels.  Modular is having seperate pieces for things like your buttons, sticks, etc and the assembling them in whatever order you need at the time.  Here's a view of the seperate pieces I plan on having, along with the CP cutout which they will fit into.  SO I can have all those different layouts without having to store a half dozen full sized panels.  I only need to make room in the cab (or wherever) for the small seperate pieces that aren't being used.
Is anyone familiar with Dzus type 1/2 turn fasteners?  Are they available in depths deep enough that they'd be usable on a CP?
« Last Edit: March 09, 2004, 12:46:08 pm by DougHillman »
Lilwolf
« Reply #9 on: March 09, 2004, 02:53:14 pm »
btw, it think modular control panels are pretty cool
before you finalize your design... shouldn't you consider the COMBINATIONS of controls you have?
It should be pretty easy to swap... why would you have a spinner and trackball with a flightstick AND 7 buttons?  What are you trying to take care of?
IE, you might have 4 modular plates... forget about different size spacers... or random locations for those spacers.  Because hopefully you will be setting up your controls for the games... not tyring to come up with a bunch of generic solutions..
I liked someones approach (sorry forgot who?) who had a joystick with two buttons next to it... and then the next moduler had 4 on it.  So you can have an 8way with 6 buttons or trackball with 4... ect...  they where all the same size
DougHillman
« Reply #10 on: March 09, 2004, 03:20:27 pm »
Well, I'd have a spinner and trackball along with a flightstick and 7 buttons because with the addition of a 4/8 way, it'll cover pretty much 99% of the single player games with a generic no-fuss solution.  The bottom configuration in my initial post exhibits exactly that and will be the way it's set up most of the time so that I can jump on and play something at random.   It'll change for specific games or gaming sessions.
I want true Neo-Geo and Street Fighter layouts, so splitting the buttons between panels is not an option.
Due to the space limitations, I cannot have all modules the same size and have them all fit in a generic configuration.  I could maybe get the layout that I've pictured to work as 6" panels if I was able to combine the spinner & Tron type stick into one panel, but I've decided to go with an Oscar Up/Down spinner which will require more space that what it pictured.  It should fit in the generic layout with the removal of the spacers.
BTW, don't anyone feel rude if they wanna throw out constructive criticism or comments such as a couple people have.  The more discussion the better.  It helps anyone thinking about going modular and it may open our eyes up to better solutions than what we've got now.
DougHillman
« Reply #11 on: March 10, 2004, 04:07:38 pm »
Lexan / acrylic overlay?
Anyone put lexan on their modules?  I'd like the protection that it offered to my CPO and the replacibility factor if it happened to get scratched, but I'm now keen on the idea of how visible the panel lines would be.
I'm of the mind that a printed high quality vinyl of some sort is gonna be the way I go.  If it's black & all my fits are pretty exact it should hide the panel lines fairly well.
D
DougHillman
« Reply #12 on: March 10, 2004, 04:32:48 pm »
'Nother question.
What are you guys doing as far as hooking your modules to your keyboard encoder?  Seems like most guys doing this are using molex.
I read in one of the threads about someone using Cat5 from the modules which plugged into a multi-port RJ45 wall jack.  I LOVE that idea.  As far as I can tell, a 6-port jack should be sufficient.  P1 Stick, P1 buttons, P2 Stick, P2 buttons, Tron stick (which would sometimes be installed on the panel at the same time as the normal P1 Stick, ergo it needs it's own port to the I-PAC) and maybe one extra for something else.  This would cover every possible module configuration I can think of.
If whomever's idea this was reads this, could you post a few detail pics of this setup?
I haven't yet recieved my Opti-PAC, trackball or spinner so I don't really know how these hook up.  Would it be possible to route them through Cat5 as well?  (I'll check some online installation instructions later tonite when I get a chance, I suppose.)
D
hyiu
    • www
« Reply #13 on: March 10, 2004, 04:45:31 pm »
I'm the guy who is using cat5 with the RJ45 jacks... hee hee...  ;) ;D
but I'm not doing modular panel....
basically.... each player on my panel has 8 buttons and 1 stick...
and uses 2 cat5....
I use these because I'm building "interfaces" for my stick / panels...
so that the same stick can be re-used when I plug in a hacked gamepad...
or PSX pad... so that the same stick can be used for multi system....
as for pics... hmmm.... I'll need to dig it back out....
I believe I have some pics for the xbox hack and my sticks in the console section.... will need to do a search... and seems like the search button doesn't work for now....
[edit] here you go....
http://www.geocities.com/hyiu2/pics/gaming/
click on the xbox*.jpg....
[/edit]
« Last Edit: March 10, 2004, 04:47:43 pm by hyiu »
NoOne=NBA=
« Reply #14 on: March 10, 2004, 06:52:38 pm »
I don't have any pics posted at the moment.
I'll reply here once I get them posted.
I'm still working on the panels and such, in addition to all of life's other impositions, so that's taking alot of my time.
What I did though was cut a hole through the back wall of my control panel area and mount the 6-port wall jack directly to the back wall.
The permanent wires go from the wall plate backward to the I-pac inside the monitor area of my cab.
The modules are using 3' patch cables hacked in half.
I picked up the patch cables free when we moved into our new building at work, so it save me from having to actually crimp the male ends onto bare wires.
telengard
  • Last login:May 01, 2024, 04:25:48 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #15 on: March 10, 2004, 10:36:46 pm »
Very good idea going modular.  If you're looking for another example you can check out mine:
http://users.adelphia.net/~bsturk/mame.html
And I have a marble madness panel.   :)
Just haven't tried it yet with AnalogMame ( or found someone to play with that likes the game either )
Good luck with your cab...
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
DougHillman
« Reply #16 on: March 12, 2004, 01:38:44 pm »
Bah.  I no longer have any interest in Dzus fasteners.
telengard, I'd seen your site before and really like the idea of using rack mount stuff.  Donno why that never occured to me in the first place, as I'm a DJ. :)
What I don't want though, is much in the way of visable hardware.  I'm not overly keen on the abundance of rack mount screws that are on the modules.  I'd also like something that's quicker and easier to change.
While discussing this with my girlfriend she pointed me in a good direction.  She talked about some sort of friction fit.  Her approach was a little different than what I'm thinking of now, but it got me going in this direction.
What I'm invisioning now is a system with something like the rack mount rails in the base control panel shell with sets of pins imbedded in each module.  What I see are some sorta pins with the springed ball bearings at the end.  Anyone know what I'm talking about?  Any idea where to get something like this?
Garrett
  • Last login:December 26, 2013, 04:53:15 pm
« Reply #17 on: March 12, 2004, 02:08:12 pm »
I'll add my 0.02 here - I recently finished my modular panel, and it's working out really well so far (but still needs a bit of tweaking).  I've got 11 panels, with a variety of buttons, joysticks, spinners, and a trackball.  Each panel is hooked onto a bar at the top of the CP box and then connected at the bottom with a rubber latch.  I wanted to make it easy to move panels around and not mess with screws or bolts.  I can add or remove a panel in a few seconds.
My wire connections are via molex connectors.  I recently had to move all of my wiring from the main part of the cab to directly below the CP box because it was bunching up too much.  Works great now.  The unused wires hang down out of the way.
The panels themselves are constructed of 1/2" acrylic with a cover of 1/8" translucent blue plexi.  I'm hoping at some point to illuminate the panel from below.
Pics are here:  http://home.wi.rr.com/mschwab/mame.  Still doing a bunch of tweaking, touchup, adding artwork, etc, but as far as functionality, everything works perfectly.
I have a bad feeling about this.
DougHillman
« Reply #18 on: March 12, 2004, 03:29:58 pm »
Good job Garrett.  Yours is one that I've looked at before, got the site bookmarked and will probably end up with a wall full of inspiration as you have there. :)  I need to start printing out all the modular panels.
Again, as with some of the other options I've contemplated, I'm really trying to come up with something fairly solid, easily removable, and visually unobtrusive.  My GF suggested (along with some other ideas during our brainstorming session) a method similar to yours.   Hooking under a rail in the back and then some sorta latch or friction fit in the front.  We'd have to find some way to do it with no visible latches though, and I think that might be difficult.
I really like the idea of using acrylic for the entire panel and lighting it from beneath.  I've seen some interesting stuff done with etched acrylic that has LED's or EL lighting run around the edges.
I'd give my left nut for a nice SW pin like you've got there.  You think I could sell a testicle on the black market for enough to buy one? ;)
I'm a bit of a SW fan myself.  Here's a pic of one of the walls in my (unfinished) basement.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #19 on: March 12, 2004, 03:38:48 pm »
I've got absolutely no experience with modular designs, but if i were to design one, I would probably have all the module freely sit on rails that are secured by a single bar on the front of the panel that hinges up and down. The back of the panel would be slotted to hold the module's "lip" in place.
That way you have only one fastener to open/close at a time and swapping modules would be quick.
saint ganked my avatar.
DougHillman
« Reply #20 on: March 12, 2004, 03:49:36 pm »
I'm pretty sure I've seen this done somewhere.  Can't remember exactly what I thought of it though.  Hopefully if it rings a bell, someone can post a link.
This is an idea that has some promise, as I could probably make it pretty unobtrusive.  I could deal with one Dzus fastener or something similar being visible to lock the front retaining bar in place.
NoOne=NBA=
« Reply #21 on: March 12, 2004, 04:12:19 pm »
My swappable panels were held in with a piece of metal that slid under wood in the back, and roller-type cabinet catches in the front.
That made them completely tool-less, and allowed them to be swapped in a matter of seconds.
While that worked fine for the swappable panels (because they sat on top of the sides of the control area, and couldn't go down), it won't work for the modules I'm building because they need something to keep them from falling into the control panel area.
The only problem I had with the method above is that the cabinet catches had to be bent back into place occasionally, to prevent the CP from jiggling forward and back.
DougHillman
« Reply #22 on: March 12, 2004, 04:32:31 pm »
Those cabinet catches were exactly what my GF was describing.  She couldn't tell me what they were used for and I couldn't figure out what the hell she was talking about though. :)  Now I get it.
Is there any reason you couldn't make a CP frame like I'm doing with inside ledges for the cabinet latches on the modules?
NoOne=NBA=
« Reply #23 on: March 12, 2004, 05:06:46 pm »
I re-framed on the front and back, inside the CP area, so that I would have something there to hold the T-nuts I'm using.
I opted for the screw-in approach because it seemed more permanent to me.
Using the cabinet-style connector bolts, it's not really that big a deal to me to screw/unscrew them with my cordless screwdriver to swap them.
NoOne=NBA=
« Reply #24 on: March 12, 2004, 08:12:48 pm »
Here's what I was using to hold on my swappable panels.
Here's what I'm going to.
The 6-port jack at the back is where the modules that go to the I-pac will plug in.
There is also a USB hub tucked in against the front wall, that will be used for trackballs, spinners, and such.
telengard
    • S T U R C A D E
« Reply #25 on: March 12, 2004, 11:04:13 pm »
hehe, I used to be a DJ quite a long time ago but never dealt w/ rack mount stuff until I started working with computers.  All I knew was the turntables and mixer.    ;)
I think you'd be surprised how easy it is to change the panels I have.  I have really short screws and a hand held battery powered screwdriver.  Doesn't take long at all.  The molex connectors are pretty straight forward too.  I used colored wires to make that easy.  I do agree with you on the visibility part though.  I have also found that I only really need two screws for each panel ( at least the smaller ones ) one at each diagonal.
For me it was *all* about stability.  I'm seem to be a rough player and ( unconsciously ) pull and push joysticks really hard.  What I did had to stand up to my beatings while playing Robotron!    :)
I looked for something like this, never found anything.  That would have been ideal.  The nice thing about the rack screws is that they aren't a specialty item.  But I can appreciate your idea.  That would definetly be easier to swap modules around with.
« Last Edit: March 12, 2004, 11:07:50 pm by telengard »
telengard
    • S T U R C A D E
« Reply #26 on: March 12, 2004, 11:14:31 pm »
Wow this looks just like what I've done.  I have small 1U and 2U spacers also.    That wood thing looks exactly like the metal frame I had laser cut too.  Is this something you've built?  I'd love to see pics.
I keep hearing about these Dzus connectors and think they are mis-typing Dsub.    :P
I wanted to use some kind of half turn screws but they probably wouldn't work with the rack rails I'm using.
You bring up a good point about storing them too.  I haven't figured that out yet although storing the smaller modules is easier than storing the 8 separate panels I had.    ;D
DougHillman
« Reply #27 on: March 13, 2004, 12:55:20 am »
Haven't built it yet.  Well, not outta wood at least.  I'm in the process of making a foamboard mockup to finalize the sizes & stuff.
I've got a friend's cabinet to finish before I can get to mine.   I'll post some pics of both when I get them.
Here's the home page for Dzus Fasteners
http://www.boomerangracing.com/Dzus.html is one of the multitude of places that sells them online.  Donno if they'd be something that can be picked up at a local auto store or not though.
GGKoul
  • Cheesecake Apprentice
« Reply #28 on: March 13, 2004, 01:59:11 am »
Hello
I just thought I'll add my 2 cents to this discussion.
I'm panel on making modular panels as well, but with a twist.
Mine panel is presently is a 4 player cab with a trackball in the middle and a row of start & coin bottons along the top.
My plan is to keep my existing trackball in the middle and row of start buttons on the top. Therefore forming a "T" Shape when all modular panels are removed.  See attached picture.  The area in red will be removable.
So I'm planning to connect my modular panels to the existing "T" support mounts on the side and top of the panel.  Therefore I can quickly slide a panel off and on with out losing trackball / Mouse support in Windows and I dont need to purchase a new set of player buttons.
I'm still in the planning stages as I'm still wiring everything is parallel cables.  But I plan on making the following panels.
1)  2 player per side - For 4 player games
2)  1 player per side with 2 joysticks each & six buttons in between the joyticks
3)  1 Rotary per side with 4 buttons per player
4)  1 - 270 Steering Yoke wheel per player & High/Low/Turbo Shifter for player 1
5)  1 - 360 Steering wheels per player
6)  1 - Trackball with 3 buttons per player
Once I get the IPAC & Otipac wired up with parallel cables, I'll start wiring up the panels.
-GGKoul
Garrett
« Reply #29 on: March 13, 2004, 01:26:22 pm »
Just wanted to say great ideas all around here, it's really cool to see what different people come up with while trying to accomplish the same thing.  In fact, I think it would be a cool idea to have specific section for modular designs here at the byoac site.
Doug - Trust me, I tried for a long time to come up with an idea make my panels totally clean and hide the latches at front, but finally just decided to push forward to get the project done.  I'm still considering some kind of flip down compartment that covers them, maybe something spring loaded so you could just pull it down, attach, and then let it go.
I also thought it would be nice to have the panels kind of snap down into place, with some kind of button for release.  Alas, that's as far as I got, couldn't figure out a way to do it.
I used the metal bar w/hooks idea to attach because I wanted to be able to put any control any place I wanted on the CP, and not be limited by slots or tracks or screw/bolt holes.  It works great, I highly recommend it.
Nice wall of stuf you have there.  I collected vintage figures for a long time.  What's turned out to be a rather costly arcade cabinet was actually funded entirely by selling them all on ebay.
But the pin I will never give up...   ;)
DougHillman
« Reply #30 on: March 13, 2004, 02:25:59 pm »
GGKoul, very interesting and inventive idea.  Is that 3/4" acrylic you're making your panel out of?  I'm really starting to like the idea of a wholly acrylic panel with some sorta lighting effect.
Garrett, I've got a huge collecton of original figures too.  They're not on display at the moment though.  Easier to display a pegboard wall of packaged ones that set up all the open ones in a diorama.  :)
I'm heading out to Menard's in a few minutes, chock full of ideas gleaned from the examples & discussion here.   Hopeully I'll get started on the actual CP build within a day or two.
GGKoul
« Reply #31 on: March 13, 2004, 02:54:53 pm »
It's actually Mirrored Plexi.  Call FABBACK.  Purchased from my local Home Depot.
It's mounted on 3/4 MDF.  I'm not sure if I'm going to use it.. Because its a pain in the ass to cut and drill thru.  As it cracked when I was drilled thru the plexi.   But thats because I didnt glue it down before drilling
What I going to do is design each panel to look like some original game art.  Therefore each panel to have their own colour layout.  Similar to what Frosticillus did with his rotating panel.
So for the driving panel, it'll look like a Pole Position Panel, for the rotary panel.. like Ikari warriors....  At least thats what I plan on doing.
So it's alittle different then whats been done in the past.
NoOne=NBA=
« Reply #32 on: March 13, 2004, 03:09:36 pm »
As far as hiding the hardware, a spin-off of both my designs would accomplish that.
If you built the back end so that it got trapped (like my swappable design), and then had the front end screw/pin through a hole just under the front lip, all the hardware would be hidden.
Garrett posted this above:
My take was exactly the opposite.
I was surprised by all the different GOALS posted here for which this same general design (individual removable components attached to a carrier board) seems to be the answer.
My goal for my modular system is to be able to accurately reproduce ANY arcade CP using a minimum of parts to do it.
I am switching to modular (from my current swappable system) mostly because I am tired of playing games with generic panels, or having to play off-center to the screen.
It's a small annoyance that I COULD live with; but I don't HAVE to, so I am changing it.
Many others here seem to be looking for a way to switch between several generic panels, without having to store the full panels that are not in use.
Still others are building semi-permanent controls for certain functions, while incorporating changable controls in other areas.
telengard
    • S T U R C A D E
« Reply #33 on: March 13, 2004, 03:31:56 pm »
That's pretty much my goal too.  After going to Funspot I realized that a big part of playing was the layout of the controls.  Galaga with a centered 4 way joystick just doesn't feel right to me.  I can ( within a small tolerance ) duplicate just about any panel except for the large ones like Gauntlet.  I wanted to keep the look of a vintage cabinet so that was a sacrifice I had to make.  My panel is large enough for the games I like to play.  I've also bought up a bunch of original controls for which I'll put screenshots up soon once they're done.  I just picked up a star wars and spy hunter yoke, an original berzerk joystick, tron joy, and battlezone joys.  I have a bunch of other stuff too.  My favorite to play so far is Beer Tapper with the tapper handle.  Like building the cabinet itself, collecting controls can become an obsessive thing.   :)
DougHillman
« Reply #34 on: August 12, 2004, 12:01:13 am »
Allright after an extended time of no time for cabinet building, I've been able to complete the cab I was hired to build.
Now I can get back to work on mine. :)
Anyone finished or started their own modular panels since this thread was last active?
telengard
    • S T U R C A D E
« Reply #35 on: August 12, 2004, 12:16:16 am »
Is anyone ever done with a modular panel?     ;)
Well, I finished switching over to RJ45s for my modular setup and got around to wiring the OptiPac so I can use my trackball and spinner modules.  I've been playing a lot of Centipede with a perfect layout.   ;D
I haven't seen any new ones yet, but I'm sure some folks are working on them.
~telengard
Hamselv
  • Last login:May 16, 2010, 08:08:44 am
« Reply #36 on: August 12, 2004, 02:05:40 am »
The coolest (finished) modular setup I have seen is Doc's Modular MAME: http://www.beersmith.com/mame/.
Well thought out, well built and well documented :)
SirPoonga
  • Puck'em Up
« Reply #37 on: August 12, 2004, 03:08:55 am »
I like jelloslug's rail system.
Doc's system
"Can't cover panels with lexan/art"
That's wrong.  It's possile, you just need a well thought out repeating patern that the edges of each panel match up.  Like a repeating pacman maze that I have seen as a wallpaper.
Jello's rail system is how he over came Doc's con of "Need to secure joysticks - though I overcame this one"
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #38 on: August 12, 2004, 03:24:49 am »
Doc's system
Well maybe it's not "impossible" to put art on it, but it's very hard to get it right, the seams would show, a generic repeatable pattern is not really nice, it would be very hard to design a more elaborate style of art since the controls are in different locations on the panels ...
I thought someone was working on an art idea though.
I doubt putting Lexan on it would work. That would be a tremendous lot of work and probably look really horrible. The seams would show up really bad.
« Last Edit: August 12, 2004, 03:27:42 am by patrickl »
SirPoonga
  • Puck'em Up
« Reply #39 on: August 12, 2004, 03:31:19 am »
Unless you made the seems part of your art design then you wouldn't know there were there.
