Main > Main Forum
Do I need to patch before applying adhesive vinyl
Zebidee:
For future jobs, you can minimise the tearout by drilling through masking tape (also called painters or paper tape).
If you drill a small guide hole first (say 6mm bit), you can start the wider hole from both sides first. Use a piece of scrapwood as backing for when you drill through.
