Main > Main Forum
My new rig (doing it cheap)
Pages: << < (3/4) > >>
daywane:
PC arrived today. it is doing updates now. I have not been able to do anything fun yet.
the keyboard and mouse is like something from $5 and below or allies .
the mini tower its self ... I am happy with. I am using display port. I have no problems with Display ports. I have adaptors . my OLD eyes can not tell the difference from HDMI and display ports. VCR and DVD I can see a difference . Past that nope. 8 Track to cassette yes. cassette to CD yes. past that nope. I just do not have the golden eyes and ears.
<------ ( RIP BUCKY )  After many years, I have a Bucky 2.0  :applaud: A little retard from Pinky and the Brain . NARF! Toy Australian Sheppard. 5 months old  THERE IS NO EATING CAT POOP! THE CAT IS NOT YOUR TOY! YOU DO NOT EAT MY shoes! TP IS NOT A TOY ! NARF! lol
frankrizzo2:
Batocera is a nice all-in-one linux system if you are looking at an arcade emulation type setup
daywane:
I have a few setups of batocera and even more of retropie. going with RetroBat  or big box on this one.
Honestly . I think I enjoy tinkering the most.
Till Windows 10 is supported. After that Linux. Mint most likely
RandyT:
--- Quote from: daywane on December 14, 2024, 02:42:41 am ---I am happy with. I am using display port. I have no problems with Display ports. I have adaptors . my OLD eyes can not tell the difference from HDMI and display ports. VCR and DVD I can see a difference . Past that nope. 8 Track to cassette yes. cassette to CD yes. past that nope. I just do not have the golden eyes and ears.
The only thing to be aware of, at least from what I have experienced, is that the reasonably priced adapters and cables will not support 4k@60hz.  Some won't go over standard HD at all and if 4:3, won't go over 1024x768.  I found this out the hard way when trying to feed one of those stretched format digital pinball score displays.  So it's not so much a difference in output quality, but a difference in supported resolutions.
If you are the type who likes to use CRT renderers and shaders, the added resolution from 4k can make a more convincing CRT simulation.  But if you are only doing HD, then it's not a big deal to pick up cheap adapters.
nitrogen_widget:
--- Quote from: RandyT on December 09, 2024, 11:38:05 pm ---
--- Quote from: daywane on December 09, 2024, 12:35:24 am ---I am giving my Daughter my old PC. I ordered this PC from Amazon (remember I am doing it CHEAP)
https://www.amazon.com/gp/product/B0DJXW682F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Not sure if you knew this already, but there are ThinClients which pop up on the used market now and then with pretty much the same specs and much smaller footprint.  The HP T740 ThinClient is a bit thicker than most, but has 2 SODIMM slots, an NVME slot, M.2 SSD slot and the one for smaller cards (A-Key?) for wireless, which can be used for other purposes if desired.  What sets it apart from other thin clients is that it also has a single full-size PCIE slot for half-height cards. It's virtually identical in ports as well.  The only mildly annoying thing about them (and the one you bought too) is the 4 DP ports, but no HDMI ports.  The T740 also lacks normal SATA drive connections, which can be remedied thanks to the PCIE slot, if you really need them, but the card would need to supply power to the drive as well (not sure something like that exists.)
I managed to snag a quantity of HP T740's for general/development use and they came out to about $40 each (!) with 8gb of PC4 3200 SODIMMs in Dual Channel, Wifi, Bluetooth, 64GB EMMC drive and a power brick.  Even with those specs, they make great little special purpose Linux devices (or even Windows 11 if you are a masochist).  They aren't always easy to find at that price and with those specs, but they are very upgradeable and at less than half the cost of a decent Pi (or even at the full cost), they are a no brainer.
RE: Linux
If you are heading in that direction, pick up a cheap system now (or dedicate an old unused system) and start playing.  The options for distros have become amazing lately, and Valve is even getting ready to put out a Steam version specifically geared toward gaming.  It won't be long after that we start seeing forks of that distro (if even necessary) which combines excellent PC gaming with other general use capabilities.  Once this happens, MS is is going to become irrelevant to a large chunk of the gaming market they currently have a stranglehold on.
No time like the present.  By time Win10 dies off, you'll already be well on the way to make the switch.  If emulation is the main thing you play around with, I'm not sure it would take you more than a week to not care about Windows anymore, unless there is some program that you absolutely must have and it can't be run under compatibility tools like Wine.
RE: Graphics card
What BlueGhost said.  You won't really be gaining much with that card and it doesn't even provide you with the more common HDMI ports.  If you really want to step up the graphics, you'll probably need to spend more.  But if you do, keep in mind that Linux is geared toward AMD graphics.  There are closed-source Nvidia drivers, as well as newer open-source ones which are getting better, but AMD stuff is usually more compatible out-of-the-box and less likely to have weird issues.
i'm using a thin client with usb 3 and a dual hd dock for my file server.
works great.
i have a few other thin clients with mame on them. they struggle with some CAVE games and def. won't run gauntlet legends but otherwise do the job.
i use this site to get info on thin clients and their upgrade ability.
https://www.parkytowers.me.uk/thin/
Go to full version
