Author Topic: running 2 cabs on 1 computer question  (Read 999 times)
dirt
  • Last login:July 24, 2023, 11:06:57 pm
« on: March 05, 2004, 04:34:53 pm »
 hey all,
      i need to know if i can use 1 isolation transformer for 2 monitors. i have my pole position and return of the jedi cabs side by side and want to use one computer to run both.one is for 360 games and the other is for 270 games. i am using an arcadevga card and 2 19" arcade monitors. i just want to make sure that everything is going to work ok. if anyone has any ideas or comments or suggestions please reply.
ps  i need a marquee for the jedi cab.anyone have one? never mind i just found one ;D
dirt
« Last Edit: March 08, 2004, 03:51:51 pm by dirt »
WANTED: NINTENDO CABINETS WORKING OR NOT
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
Re:running 2 cabs on 1 computer question
« Reply #1 on: March 06, 2004, 06:00:50 pm »
Well if you rember punch out used two monitors and the cab had one ISO. Just make sure there is good airflow around the ISO and it should be ok.
Curls in the squat rack !?!?!
MinerAl
  • Last login:March 21, 2023, 07:11:28 am
  • duck
« Reply #2 on: March 06, 2004, 08:46:24 pm »
KVM Switch?
dirt
« Reply #3 on: March 06, 2004, 08:50:07 pm »
KVM Switch?
wouldn't that be for 2 computers and one monitor?
dirt
bluGill
  • Last login:February 05, 2004, 06:03:02 pm
« Reply #4 on: March 07, 2004, 02:07:32 pm »
This depends on the rating of the transformer and the power useage of the monitors.   If you add up the watts the monitors use (Which Should be printed someplace on them), it must be less than the rating of the transformer.
If you will only be using one monitor at a time, there is no problem, just make sure you can't make a mistake and turn both on.
Personally I'd just buy a second transformer, they are not that expensive.
SirPeale
  • Green Mountain Man
« Reply #5 on: March 07, 2004, 02:08:48 pm »
I have to second what Blu says.  $9.00 isn't that expensive, and better to be safe...
dirt
« Reply #6 on: March 07, 2004, 04:20:29 pm »
thanks guys i will go pick up another one tomorrow ;D
dirt
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #7 on: March 07, 2004, 04:31:03 pm »
I would like to take this opportunity to say that I hate you for having a Pole Position cab and a ROTJ cab.  That is all.   ;)
dirt
« Reply #8 on: March 07, 2004, 05:01:27 pm »
hell you could of had both of these yourself. i bought both on ebay.the pole position for $61 and the rotj $39.76.
rotj   http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3270570638&category=13716&rd=1
pole position  http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3274361178&category=13716&rd=1
dirt
