Main > Main Forum
4 way - 8 way
Phreakwars:
I'm not really a fan of the Mag stick. The throw on it isn't very good IMHO. I use a servo stick in a couple of my cabs with a hidden button on top that I use to switch back and forth between 4 and 8 way. Also, the nice thing about the servo stick, is I was able to use an RGB ball top.
spisi:
Isn't there a way (using software) to have it switch automatically depending on which game you are playing? I guess you make some kind of batch file or something.
Fursphere:
--- Quote from: spisi on January 26, 2024, 12:31:41 pm ---After further review, there is also a mag stik plus. Magnetically controlled from the top of the panel. What are the pros and cons between the two stiks?
I have two leftover mag-stiks in a box. They're not great. I hated the feel of them.
Fursphere:
--- Quote from: spisi on January 26, 2024, 01:03:35 pm ---Isn't there a way (using software) to have it switch automatically depending on which game you are playing? I guess you make some kind of batch file or something.
Yes. But its complicated.
Here is one video on the subject:
spisi:
Thanks for the info! Have you used the Servo Stik?
