Main > Everything Else
any car guys here? 99 mustang v6
bobbyb13:
Yeesh.
Hope you are doing ok.
As regards the Pony car, it wouldn't be the first time that injectors stuck open from contamination.
Maybe...
Drain tank.
Add fresh fuel with a dose of methanol fuel dryer.
Change filter
Swap in rebuilt injectors.
https://m.motormanfuelinjection.com/contact.html
If those injectors are failing then some crap in the fuel caused it at some point.
That would be my approach anyway.
Best of luck in recovering from that accident!
lilshawn:
i do have a borescope camera. maybe if i can get into the intake and see an injector... hit the key to on and prime the fuel rail and see if it's dripping fuel out of the injector(s).
Falken Hawke:
Everything you've described points to the pressure regulator being stuck open. Apply vacuum to the regulator, start the engine. Pressure with vacuum should be significantly less than what you are getting now.
bobbyb13:
Or better yet, listen to this guy because he knows these cars!
--- Quote from: Falken Hawke on October 29, 2023, 04:56:25 pm ---Everything you've described points to the pressure regulator being stuck open. Apply vacuum to the regulator, start the engine. Pressure with vacuum should be significantly less than what you are getting now.
lilshawn:
thanks for your input all.
I'll probably take another stab at this next weekend here. got a couple things to look closer into anyways even if it's just throwing pasta at the wall and seeing if something sticks.
