Main > Main Forum
Portable Pac Man ideas / brainstorming
pbj:
Get an AtGames Mini, swap out the joystick, add Pac-Man to it. You can’t build anything cheaper than that setup.
Zeosstud:
A Sanwa stick with a 4lb spring and a Mister device have proven to be the combo that allows me to play the game, specifically the 9th key pattern and it work. Timing is so crazy important. I hope you find a solution that meets your needs and please share with the forum when you do.
Zeosstud
negative1:
arcade 1up has a ton of countercades, and partycades with larger screens.
any of those could be made portable, but power would have to be modified
to use a battery pack.
they also have small tabletop variations too.
update : here's their latest version
https://www.qvc.com/arcade1up-pac-man-counter-cade-1-player-new-des-ign.product.E310385.html?sc=SRCH&TZ=EST
later
ne gative 1
