Main > Main Forum
Newb questions
Cariba:
--- Quote from: bobbyb13 on July 27, 2023, 03:06:07 pm ---Yup.
1. Jamma wired horizontal monitor cabinet
2. Jamma switcher from RiddledTV
3. J-Pac
4. MAME PC
5. Any other jamma board that displays to horizontal
Don't forget an isolation transformer for the monitor.
Yes I believe there is an Isolation transformer already in place to run for the original Neo Geo MVS system.
How would the actual power be done/handled if I wanted to choose from using PCB board or PC? would the the PC always power up, but not be used when using PCB or MVS system? But then how would I safety power down the PC? or would a set up like this need two separate power switches, one for each system I want to run?
I take it when I disconnect connection to J-Pac and switch to Jamma to PCB or MVS that that is when PCB or MVS system get power?
Also, if I do not add any buttons to the system, what would I use as an 'exit' button on MAME?
Thanks in advance
AND with MAME do I not need a seperate amp for the sound?
