I'm looking to see if I can use a USB plug and play type flight-stick for mame games such as tron, and sega starwars trilogy (1994).
Even though both are triggersticks, those are two VERY different types of stick.
- TRON uses an
8-way triggerstick with a special restrictor that makes it hard to hit diagonals.
- SWT uses an
analog triggerstick.
As always, make a list of the games you want to play and figure out what controls you need for them.
http://wiki.arcadecontrols.com/index.php/FAQ#What_type_of_build_meets_my_needs.3FIf Vindicators and CyberSled are both on your list, you'll need both 8-ways and analogs.
I currently have a 2 player arcade pedestal type of set up, so I am looking to see if I can get a stick controller that I can just put on top of my arcade control top surface temporally only when I am playign these games...(sometime these flight sticks have small suction cups on bottom),
The suction cup mount option may not work well enough if you get into some vigorous gameplay.
Not sure If just any modern flight/tron stick/joystick that first would work with mame? do I have to look for something in particular?
MAME can handle a wide variety of input types so there shouldn't be any problems.
I am also considering using two of these flight sticks to play Vindicators properly.
Vindicators uses two 2-way triggersticks (8-way triggersticks will work equally well) and 4 buttons. Two triggerticks, each with a trigger and at least one thumb button will cover that.
You may want to consider building these sticks into a USB pedestal that you put in front of your main 2-player pedestal.
- This approach is much larger than a set-a-box-on-top-of-the-CP approach, but the height/ergonomics and stability should more than make up for that.
I don't mid if I have to hard wire them into my system's IPAC board as well...(but would love USB instead - as I currently have X box controllers set up on USB)
You can wire 8-way triggersticks into the IPac., but you can't do that with analog triggersticks.
With either type, a separate USB encoder is a viable option.
Also, interested to see if I can also do something similar & 'temporary' for adding (plug and play) rotating joysticks needed for Ikari warriors
For mechanical rotary (clicky) joysticks like the LS-30 or Happ mechanical rotary, there are encoders that can handle both the 8-way joystick and the 12-position rotary switch.
- Ultimarc's U-HID can decode the rotary switch by using 4 diodes and specfic wiring connections to output a quadrature waveform like a spinner/trackball for the U-HID. See
this PDF for details.
- Another encoder option is using the KADE
miniArcade 2.0 firmware on an Arduino that converts a change of the rotary switch position into a keystroke like "[" showing that you turned the switch left or a "]" for right.
NOTE: A Pro Micro will only support one rotary joystick (purple "Rot 2B" 32u4 pin 32 is not available on this board), but that pin is available on the Micro, Leonardo, and Itsy-Bitsy boards which support two rotary sticks. (click to see larger)
One problem you might run into is finding this type of stick since Happ and SNK no longer make them.
- The only mechanical rotary joystick currently being manufactured is the 12-way mod
here for the Ultimarc Servostik or J-Stick.
- There are sticks like the Happ Super, Happ Competition, LS-32, LS-38, or Zippyy that you can mod to add a rotary switch by either adjusting the height of the default handle/shaft (possible to do with the Super or Comp)
or changing out the shaft (these sticks all have a 10mm shaft) and adding a 3d printed handle like
this LS-30.
Another concern with mechanical rotary sticks is the amount of clearance (~4.5" IIRC) needed under the panel for the rotary switch.
- Once again, you may want to consider building these sticks into a USB pedestal that you put in front of your main 2-player pedestal.
Here's a list of the approximately two dozen games that used this type of stick.
- Most use two player buttons. (i.e. Fire and Grenade) Ikari III - The Rescue is the only one that uses three player buttons.
- Scroll down to see the MAME settings you
must change to get the rotary function to respond correctly and reliably.
http://wiki.arcadecontrols.com/index.php/Joysticks#Mechanical_Rotary_Joystick_Games_.28LS-30.2C_Happ_Mechanical_Rotary_Sticks.29Scott
