Author Topic: Model 2 1.1a only shows gamepad devices, my A-Pac is not selectable.  (Read 1910 times)
FSD
  • Last login:June 04, 2023, 08:32:44 pm
Hi,
     I've just finished my Daytona cabinet using all the standard IO linked up to an i3 PC using A-PAC and a custom Arduino for gearbox decoding and VR control.
Everything works great in Mame and Model3 emulation (albeit a little slow on an i3).
My problem is that I really want to get Model 2 working but when I try and change the controller settings my A-PAC doesn't appear as it seems like it is hardcoded for 4 Gamepad controllers. None of which seem to map to the A-PAC.
Does anyone have any ideas how this can be overcome. I cannot be the first one with this issue.
buttersoft
  • Last login:Yesterday at 09:57:34 pm
  • Is running at 15kHz
Re: Model 2 1.1a only shows gamepad devices, my A-Pac is not selectable.
« Reply #1 on: June 04, 2023, 07:36:33 pm »
Yeah, M2emu doesn't like more than about 3 controllers. If you use Boomslangnz's FFB plugin, which you need in order to get FFB anyway IIRC, there's a tab in there that will let you map your controls to the emulator. I was having the same issue, and that fixes it :)
FSD
« Reply #2 on: June 04, 2023, 08:32:44 pm »
Thanks for the tip. I've downloaded it and had a quick look but it's getting late and my machine is not in the house so I will apply the changes tomorrow.
holmes
  • Last login:October 22, 2025, 03:01:50 pm
« Reply #3 on: June 11, 2023, 02:31:57 pm »
Not sure this if is the cause of the problem but there may also be the question of the type of controller interface in the conf file. If Xinput=1, then a DINPUT wheel is not recognized.
