Author Topic: trackball question  (Read 1190 times)
wfg97079
  • Last login:March 24, 2023, 10:11:50 pm
trackball question
« on: March 03, 2004, 02:11:22 pm »
I have a control panel with a  2.5 inch hole in it, does this mean I would need a 2.5 inch trackball?  just not clear on what is measured to determine trackball size
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:trackball question
« Reply #1 on: March 03, 2004, 02:59:46 pm »
not necessarily... the size of the trackball refers to the overal diameter of the ball.  Even a 3" trackball (depending on flavor/type highball, vs highlip, vs standard) doesn't expose ALL 3 inches above the CP.
What was the control panel from originally (that would help some)?
It's *probably* a 3" trackball as the other "normal" sized tracball diameter is 2 and 1/4" (for the ball itself, not the hole, mind you)
Hope that helps...
rampy
wfg97079
« Reply #2 on: March 03, 2004, 03:11:50 pm »
very helpful
the panel is from a pacman that was converted to centipede
so a 3" could work?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: March 06, 2004, 06:58:35 am »
Generally, a 3" trackball uses a 3" hole, and a 2 1/4" ball uses a 2 1/4" hole, but that's not why they are called that.  (rampy right in that the ball diameter is whatever size the TB is called.)
All arcade trackballs have a "lip" or "rim" around where the ball sticks out of the case.  The lip is usually ~1/4" wide.  So, if you don't mind the ball being lower than normal (ie: the lip under the CP instead of level with the top of the CP), you could use a 3" ball in your 2.5" hole.  If you use a 2 1/4" TB, you'll have a 1/4" gap between the lip and the CP.
Look at happs mounted view to see the outside of the lip diameter to be 2.99", and the exposed ball to be smaller than that.
Robin
Knowledge is Power
rampy
  • *shrug*
« Reply #4 on: March 06, 2004, 09:54:23 am »
Oy, I did dork up my assumptions though...  I hope I didn't steer wfg too far off the track...  listen to u_rebel (he knows what he is talking about and check the happs mounting diagrams he linked to...
disregard the man behind the curtain...
sorry about that wfg...
rampy
wfg97079
« Reply #5 on: March 26, 2004, 07:55:00 am »
OK
I have some pics of the panel
posted at http://www.miltonsoffice.com
Let me know what you think aould be the best trackball size for me
Thanks again guys!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:21:09 pm
« Reply #6 on: March 26, 2004, 08:03:10 am »
I think that 3" is no good with that hole. Even tho it will fit, it will be low and your hand will be hitting the part of the Hole-CP. You need a ball that will show/lift up higher than the hole, so I think the 2"1/4 should be perfect, unless you wanna make the hole bigger and shove in a 3".
Free VGA Breakout Cable
paigeoliver
  • Awesome face!
« Reply #7 on: March 26, 2004, 09:45:36 pm »
Looks like a hole for a 2.25 trackball to me. Which is also the size used by Centipede.
