Author Topic: Horizontal width on 20" Hantarex Polo/3  (Read 717 times)
jate6347
  • Last login:March 28, 2023, 06:39:02 pm
« on: March 22, 2023, 01:31:31 pm »
Hi
Anyone have an idea which of the two coils on the pictures is for horizontal width (screen size)?
The monitor is an 20" Hantarex Polo/3.
/Jacob
« Last Edit: March 22, 2023, 04:13:22 pm by jate6347 »
grantspain
  • Last login:Today at 04:54:38 pm
Re: Horizontal width on 20" Hantarex Polo/3
« Reply #1 on: March 22, 2023, 08:23:27 pm »
left hand side coil width, right hand is linearity
there is horizontal size pot on the remote board, its marked h.amp
jate6347
« Reply #2 on: March 23, 2023, 11:13:29 am »
Hi grantspain
Thanx for the tip about H. Amp pot. That did the job :)
I wasn't much into adjusting the coil as it's a little more difficult to reach for me.
Do you know the difference between adjusting the horizontal coil and the H. Amp?
grantspain
« Reply #3 on: March 23, 2023, 01:19:18 pm »
the width coil is more like a preset level whereas the h.amp is the main adjustment
sometimes on hanty chassis if the width coil is badly adjusted you can get issues whereby the side pincushion is bad and width won't go full range
even worse is when the width control circuit fails and someone uses the lin coil to bring the width in, then when you fix the width circuit you get all sorts of compression issues
