Main > Main Forum
2023 Budget PC for MAME?
Pages: << < (4/6) > >>
markran:
For emulation, IMHO by the time you've bought everything for a new build, these days you can usually pick up a used corporate PC off Ebay and get more performance per dollar. Remember that single-core performance is what matters with most emulation.
Below is the Ebay search I use to find likely candidates for emu builds. My recent build was an HP ProDesk small form factor PC with an i5-4570, 8mb RAM, 500gb HD and Win10Pro for less than a hundred bucks delivered. These corporate desktop PCs have nice cases designed for IT depts to service easily and are being assembly-line recycled by the thousands as they come off of 5 year amortization. I added a cheap used GPU (>5 yr old) and it runs pretty much everything I throw at it.
https://www.ebay.com/sch/i.html?_oaa=1&_dcat=179&_fsrp=1&rt=nc&RAM%20Size=16%20GB%7C8%20GB%7C4%20GB&Processor=Intel%20Core%20i3%204th%20Gen%2E%7CIntel%20Core%20i3%206th%20Gen%2E%7CIntel%20Core%20i5%204th%20Gen%2E%7CIntel%20Core%20i7%206th%20Gen%2E%7CIntel%20Core%20i7%204th%20Gen%2E&Processor%20Speed=3%2E50%2D3%2E99%20GHz&LH_TitleDesc=0&Operating%20System=Windows%2010%7CWindows%2010%20Home%7CWindows%2010%20Pro&LH_PrefLoc=1&_nkw=pc&_sacat=0&LH_BIN=1&_sop=15
Zebidee:
--- Quote from: nitrogen_widget on February 15, 2023, 07:13:50 pm ---
--- Quote from: BlueGhost on February 13, 2023, 03:44:04 pm ---I've been using Ryzen powered mini pc's lately.  The Lenovo ones with a 2400GE Ryzen can be had for around $150 on ebay.
Will that play the 3d games though?
Killer instinct 1 & 2 for example?
Ex-corporate desktops are OK and I've happily used plenty of them before. The HP Pro ones, for example, are good. However, they can have their own issues and inflexibilities. This time I wanted to do something different.
Just finished installing, into my mate's cab, that Core2Duo E8600 3.33Ghz RAM 8GB Win7 HD6450 (replacing the old Lenovo desktop P4, 3rd cab from left in sig), runs Killer Instinct fine (also all other games I tested it with). Never got around to testing it with anything more challenging than that though.
Can't tell you how much it all cost exactly, bought the parts pre-COVID, but probably less than $120 for each set. Uses an Asrock over-engineered motherboard (G41C-GS) for simplicity, reliability and stability. They are designed for overclocking, though I don't actually intend to do that. One cool feature of these Asrock boards is that they still support an IDE connection, in addition to 4xSATA, so I can use both modern SSDs as well as the pre-existing IDE DVD drive that is already installed in the cab.
I liked the Asrock motherboards so much I bought 3 of them, and also 3 x identical HD6450 GPUs (now all flashed with ATOM-15, so work with CRT TV from boot) so setting up multiple systems can be done by just cloning the system SSD. Worked immediately using the Loewe CRT TV, connected via VGA-SCART, installed in the cab (though I still re-installed CRT_emudriver again, to tweak/optimise the settings for the Loewe TV).
It is very important that the system would work immediately, as I travelled halfway around the world with just the essentials (motherboard, GPU, RAM, CPU, cooler and an SSD) in my luggage. No case. The system needed to work "right out of the box" as my mate is not a tecchie, didn't even have a VGA monitor at home. Would've been impossible to setup otherwise.
Installation now complete, the system does everything it needs to do, including running Attract Mode effortlessly. My buddy is very happy.
Interestingly, this system is just slightly above minimum spec recommended for MAME:
https://docs.mamedev.org/initialsetup/mameintro.html
Kayden:
I don't have anything but I'm in the same boat and wanted to say long time no see.  :cheers:
javeryh:
Hmmm... so then something like this should be more than enough, right?
Dell Optiplex 5040 SFF
Intel Core i5 6500
8GB RAM
500GB HDD
I could throw in a cheap GPU for shaders and call it a day... any GPU recommendations?  The HD6450 Zeb mentions is like $12 haha.  Will that get me some fake CRT scanlines?
dmckean:
One advantage to the Ryzen 2400GE mini PCs mentioned at the start of the thread is then a decent GPU built in so that saves some money.
Go to full version
