Author Topic: "Fixed" 39k7600 issue, Screen is beautiful but fades dims out 10 minutes later  (Read 1427 times)
Customcade
  • Last login:March 08, 2023, 03:35:24 pm
Wells 39k7600 issue, Screen is beautiful but fades dims out 10 minutes later.
I can leave the game on and shut the monitor off separate for a few minutes turn it on and it's a nice crisp display again but few minutes later it slowly dims out to a blank screen.
Last time I did a cap kit was probably ten years ago but figured I would ask before I jump in a replace stuff that was perfectly fine type thing.
« Last Edit: February 17, 2023, 03:11:17 am by Customcade »
Ropi Jo
  • Last login:January 30, 2024, 04:26:37 pm
Slow fade to black is usually the heaters going out in the neck. I don't know your monitor. I'm an old school TV engineer. Check for dry joints on the tube neck conector and around the LOPTX.
Customcade
Cool thanks for the reply and will check it out.
Been over a decade since I last did the cap kit and don't remember if I can or cannot pull the neck board without discharging it first.
Customcade
Are these caps leaking, looks like toothpaste and not hot glue.
Customcade
Couple other spots
Customcade
Final example
grantspain
  • Last login:Today at 02:26:48 am
you would need to monitor the hv and b+ to prove whats going on
that is just factory glue around those caps
the sort of fault you describe is more likely bad solder joint and i would look in particular around crt socket and rgb input but in general the entire chassis should be investigated
i don't have any experience with this size tube but from previous readings I have seen known issues with 39" tubes and failure similar to this
buttersoft
  • Last login:March 22, 2024, 12:55:20 am
  • Is running at 15kHz
i had a bad solder joint like than on the neckboard connection for the G2 that made the screen slowly go dim, but it was like a thermostat, and kept fading in and out about once a minute.
Customcade
That's what this is doing, it's acting like a heater issue.
I checked the back side of the neck board and looks good but will just have to pull the main PCB and look them over again.
I was just hoping to fix it without having to pull it out again.
grantspain
next time it happens increase the screen volts on the flyback to see if you obtain a raster, that will eliminate a load of issues
Customcade
Will definitely try it, I have not played with any setting's on anything or touched any of the pots for it yet.
It's a nice crisp clear still display when it's working it just fades out after a few minutes after it seems to heat up some.
Ropi Jo
If you turn the lights down in the room you'll clearly see the tube heaters. Watch for the heater going out when the issue occurs.
Customcade
It ended up being bad solder joints from the manufacture.
Mine all still looked solid shiny and purdy from the cap work I did a decade ago.
I seen at least three points that didn't look good at all so I got those three and then there was about ten more that were questionable if they had a hairline crack so I just hit them all with some heat and added a little fresh solder since I already had it out might as well type thing.
Put it back in and I let it run for 2-3 and was perfect but now the screen was actually too bright where the black was more grey and the white color was too rich so I just barely touched the screen pot on the flyback and turned it down a hair and boom it looks like a brand new screen again.
Thanks for all the help and suggestions, glad it was a free fix and one I could tackle with all of your help again.
buttersoft
glad it was a simple fix!
