Main > Main Forum
Graphics settings
Pages: << < (2/3) > >>
KenToad:
Looks like the same vector settings from mame.ini, so it might work to just change those values by using a text editor. I'm not sure if you also need HLSL on or off to make the vector settings active, though.
Tommy714:
The settings are already set to 1 in the MAME.ini file (see images).  I also attached the Direct 3D portion of the MAME.ini file with the HLSL settings in them.
Tommy714:
The plot thickens.  The MAME start screen looks different depending on how I launch the game.  The white one is from the GUI, and the blue one was launched from Attract Mode.
KenToad:
Try turning HLSL off in the mame ini.
Tommy714:
Narrowing it down now.  I can go into the "Slider Controls" in the settings menu (tab) once in the game itself, and adjust the "Beam Width Maximum" from 4 to 1, and it's fixed.
Now the new problem, it doesn't save the adjustments.  I have to re-adjust it every time I launch from Attract Mode.
Go to full version
