Main > Main Forum
Happ button to remotely start/shutdown pc?
Stormy151:
If it's a momentary, it will work. But beware, some momentaries are normally closed, and the circuit opens when you flip the switch. Not paying attention bit me in the butt a while back.
Be sure it's a N.O. switch.
They do make momentary toggles. Other electronic sources are:
www.mouser.com
www.digikey.com
I believe Mouser has a $25 minimum order though...
hulkster:
well i did a google search for "momentary toggle switch" since i didnt know the official name before...and found a few sites. this is what im looking for http://www.holley.com/HiOctn/ProdLine/Products/NOS/NOSCA/15603NOS.html but how can i tell if it will work or not?
Stormy151:
That one will probably work, but it looks like a 3 position, On-Off-On. The center pole is the common.
Stingray:
Yeah, that three position switch should do the trick.
-S
bioart:
I think I came up with a solution that works for me... my coin door had four buttons inside for rst/maintenance etc. I rewired two of them and used the wiring harness to wire them to the motherboard headers. I also wired the lights to the 12V power from the PC...
I may wire the other two buttons to the ipac sometime later... :)
