Main > Main Forum
What are the all available 4-8 way* top* switchable joysticks?
Pages: << < (2/2)
StefanBurger:
--- Quote from: Zeosstud on January 12, 2023, 05:13:40 pm ---if you got room for a button, you can now switch sanwa joysicks with just a press of one.
https://thunderstickstudio.com/products/tos-grs-4-to-8-way-restrictor-all-in-one-kit
Enjoy!!
On Retropie you can install the script for automated change, based on game selection. So no need for installation of the button at all required.
BR Stefan Burger
Justin:
Thanks Stephan!   I just looked and it seems I may have enough room at the bottom of the joystick to install the hardware.
Do you know how much more height it adds to the assembly under the panel?
Also, I don't know the model of my sanwa. Do you know if this one is compatible?
leapinlew:
I'm using the GRS option and I'm using windows. I've got mine setup to switch automatically, without the button by making a call to the controller via batch before the 4 way games and before the 8 way games. It's a quality product, if you're using a Sanwa.
Justin:
--- Quote from: leapinlew on January 15, 2023, 02:04:42 pm ---I'm using the GRS option and I'm using windows. I've got mine setup to switch automatically, without the button by making a call to the controller via batch before the 4 way games and before the 8 way games. It's a quality product, if you're using a Sanwa.
I like it!  Can you do me a huge favor?  Can you measure the total distance from underside of the TOP PLATE of the controller, all the way to the absolute
Bottom of the servo?  I think I may just have enough room for this!
Fursphere:
I just put an 8-way octagonal restrictor plate in my sanwas.
https://a.co/d/d2U6MsF
Pages: << < (2/2)
Go to full version
