Main > Main Forum
Wire Management
Pages: << < (2/2)
Tommy714:
This should give you all you need!
chris_lemasters:
--- Quote from: Tommy714 on January 17, 2023, 08:34:21 pm ---Well, it's pretty much done.  I have to add a trim piece under the control panel, but that's easy.
I have the stuff I need for the bezel and screen cover.  Just haven't gotten around to it yet.
Thanks all for the help.
Would you mind posting a picture of how you ultimately wired things up (wire management)?  Thank you - nice looking setup!
lilshawn:
honestly, it really doesn't matter HOW you do it... or even IF you do it... unless you had a transparent panel that is going to make it visible, simply bundling the wires together to keep them tucked out of the way, in line with the rest of the harness is going to be plenty good.
having a good color code system goes WAY further in the cabinet than butthole clenched to the millimeter wiring. I'd rather deal with a rats net of wires on a panel that I can easily ID by color, than that an OCD looking, super tight, wire route job... all made of ONE color... ziptied every centimeter... that is literally impossible to troubleshoot without cutting the damn thing to shreds to get at one wire.
bundle player 1 controls together... bundle player 2 controls together. bundle the 2 bundles together.  :cheers: bob's your auntie.
Pages: << < (2/2)
Go to full version
