Main > Main Forum
Tail Gunner - no sound
spisi:
Thanks Scott. Having trouble with this game saving high scores...
PL1:
--- Quote from: spisi on December 03, 2022, 05:30:55 pm ---Having trouble with this game saving high scores...
Hiscore plugin not working in Tailgunner for me, either, but I haven't dug into it. :dunno
https://docs.mamedev.org/plugins/hiscore.html
- Running MAME from command line with -verbose might help you narrow down what is and is not working.
If you can't get the plugin working, save states are working for this game.
- Make a simple "tailg.ini" file like this that enables autosave.
--- Code: ---#
# CORE STATE/PLAYBACK OPTIONS
autosave 1
--- End code ---
- It will throw an error the first time you run it with the new .ini because it didn't autosave last time you exited the game.
- Second time you run it, it should work. :cheers:
- AFAIK the only downside to this approach is the momentary "State successfully loaded" popup window when you launch the game.
spisi:
That did the trick! The Mame Whisperer comes through yet again! :applaud:
PL1:
Glad to assist. ;D
