Main > Main Forum
Silver Strike Bowling 2005 faulty PC
lilshawn:
the overheating icon thing is something that just seemed to happen with some boards on some bowing machines (we had them on route)... it seems resolve itself for a while with a reboot. i think it has something to do with the bios reporting weird numbers to the os... and i'll explain why...
I had an older GT 2010 box (all the IT games use a similar boardset) I did some work on it the other day, and the bios reported the CPU temp in the actual bios as 65525 and the system temp as 65534 it was obviously not overheating, but weird nonetheless. not sure if it (the bios) was modded byt IT to output particular values or what... but the game (upgraded up to version 2015) in the operator menu-> system info, properly showed the temp value in degrees Celsius despite the weird numbers in BIOS.
so i guess what i'm saying is that it (weird temp numbers) was probably patched later on in software (if this was the case.)
