Author Topic: Which FE can be navigated by G27 D-Pad  (Read 2875 times)
connormmii
  • Last login:August 04, 2025, 04:19:00 am
« on: September 18, 2022, 09:59:56 pm »
Putting together a driving cab and I'm currently using Maximus Arcade (I know!!). For some reason it will recognise the wheel but will not allow me to map any of the buttons to navigate the menus. Any suggestions on a suitable front end that will allow me to do this without having to keep a keyboard handy?
baritonomarchetto
  • Last login:Yesterday at 01:50:15 am
Re: Which FE can be navigated by G27 D-Pad
« Reply #1 on: September 19, 2022, 01:12:11 am »
I have not a G27, but FEEL supports joypad inputs (up to 15 buttons).
anchounio
  • Last login:November 18, 2025, 01:58:38 am
« Reply #2 on: September 19, 2022, 06:32:32 am »
Any if you use JoytoKey
nipsmg
  • Last login:October 21, 2025, 01:54:35 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: September 19, 2022, 07:30:06 am »
I created this theme for launchbox/BigBox that uses the wheel:
http://forum.arcadecontrols.com/index.php/topic,166542.msg1755605.html#msg1755605
connormmii
« Reply #4 on: September 19, 2022, 10:14:59 pm »
THAT LOOKS AMAZING. Does it allow you to have just one list for all driving games regardless of emulator and once selected it boots the game with the correct one?
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« Reply #5 on: September 26, 2022, 06:33:51 pm »
I'm starting to look around for suitable TVs for this project.  Best buy has some cheap 32" 720P TVs I'm thinking about picking up. Thoughts on if those will do the trick? I believe they are LED trchnology.
buttersoft
  • Last login:November 18, 2025, 07:17:10 pm
  • Is running at 15kHz
« Reply #6 on: September 27, 2022, 02:49:39 am »
Err, this project being your twin Daytona 2? OR did you end up buying different cabs?
I presume the TV's have HDMI or DP inputs, so they'd probably work fine. At 720p i would imagine they are LCD TN panels, which are fine for 60FPS driving games. If you're super keen on sim stuff as well, i'd go higher res and higher refresh rate, but that's going to cost. And then you'd need a beefier PC to take advantage.
Any i5 or higher processor newer than 10 years old, with an Nvidia 960 GPU or better, is going to cut it for most TP games and just about anything else mentioned on here at 720p, i would think.
vandale
  • Id 10 and t error
« Reply #7 on: September 28, 2022, 05:24:29 am »
Be careful with Launchbox/bigbox as it has input limitations to the first 12-14 buttons on a device and the g25, g27, g29 etc have more than that which makes some buttons unusable. Was very frustrating when setting up my twin racer
Cheers
