Software Support > GroovyMAME
Two Video Cards — Nvidia 3070 ti & AMD
Rion:
--- Quote from: buttersoft on September 13, 2022, 08:56:08 pm ---i like a card with an analog output and no dot clock lower limit, myself. I suppose an RX 580 is going to be more powerful - I think that's as high as crt_eumdriver supports now. But you need to make sure you get a compatible hdmi- or DP-to-VGA dongle that can handle 15kHz and also composite sync, if you need that. A lot of cheap newer dongles don't work. I bought like a dozen different ones from Ali and eBay and only one worked. The Tendak adapters won't. The fricking HDMI Fury 2 won't either. That said, a lot of generic older AG6200-based dongles will. Some new ones still use the same old setup, so will work also - you generally have to go brand name like uGreen or Belkin or Comsol or something, but testing one is the only way to be sure.
The question is, does it support Interlaced resolutions via DP2VGA
Navigation
[0] Message Index
[*] Previous page
Go to full version
