Author Topic: This should be interesting  (Read 7701 times)
  • Last login:Today at 12:19:32 pm
« on: August 08, 2022, 09:56:59 pm »
I just bought 16 CRTs from a guy for 200 bucks total.
I had to drive 4 hours each way, but it will be worth it in the end.
I will post the status of the haul here.
Re: This should be interesting
« Reply #1 on: August 08, 2022, 09:58:35 pm »
This is going to be fun.
Sent from my Pixel 6 using Tapatalk
« Reply #2 on: August 08, 2022, 09:59:48 pm »
I need to add a shelving unit in my basement to store these.
I will get to that later.
« Reply #3 on: August 08, 2022, 10:01:04 pm »
First monitor plugged in...
Works just fine. I haven't made any adjustments yet.
19k7901
bobbyb13
  • Last login:March 14, 2026, 03:07:11 am
« Reply #4 on: August 09, 2022, 12:44:49 am »
Sweet score.
I can't even get one decent one here for twice that $$.
Zebidee
  • Last login:Today at 04:17:57 am
« Reply #5 on: August 09, 2022, 03:49:28 am »
Nice one  :cheers:
buttersoft
  • Last login:Today at 01:33:22 am
  • Is running at 15kHz
« Reply #6 on: August 09, 2022, 07:44:00 pm »
Man, i'd love some 19" spares :)
« Reply #7 on: August 09, 2022, 10:48:17 pm »
Monitor 2 looks good.
Kortek something or other.
« Reply #8 on: August 09, 2022, 10:51:13 pm »
Monitor number 3 is good.
D7700
bobbyb13
« Reply #9 on: August 10, 2022, 04:33:19 am »
Ok, so just keep teasing.
$200/16= $12.50
Plus fuel
Want to triple your investment + and send me one for $50.00 plus shipping?
 >:D
Now I am starting to wonder what year my TPG shows actually-
« Reply #10 on: August 10, 2022, 07:07:01 am »
did you get any extras like, spare adjustment boards?
« Reply #11 on: August 10, 2022, 07:55:24 am »
Sorry. No accessories.
Are you looking for something in particular?
I might have it lying around my shop.
  • Last login:March 08, 2026, 07:17:46 pm
« Reply #12 on: August 10, 2022, 12:58:40 pm »
posting just to see the updates  :cheers:
good haul. i'll bet 99% of them work fine
« Reply #13 on: August 10, 2022, 01:12:54 pm »
Hehe.
I think so too.
« Reply #14 on: August 12, 2022, 11:51:09 pm »
I tested 3 more. All Good.
2 x 19k7901
1 x 19k7203
I will get a bunch more tested this weekend.
It has been slow going because I have to make room for all of these in my shop.
Just some shelf space juggling.
Only 10 more to test.
bobbyb13
« Reply #15 on: August 13, 2022, 02:08:46 am »
Pictures or it didn't happen.
I really look forward to an Alpha Centauri visit at some point.
« Reply #16 on: August 13, 2022, 07:59:32 am »
Here you go Bobby.
« Reply #17 on: August 13, 2022, 08:01:17 am »
It is funny. People will fly halfway across the planet to visit here, but an hour drive is too much for a lot of people.
« Reply #18 on: August 13, 2022, 11:47:36 am »
Heh. Finally a broken monitor. I was adjusting the vertical hold and it went into vertical collapse. I will fix that up after I test all of the other monitors. Figures the warranty is expired. What a ripoff.
bobbyb13
« Reply #19 on: August 13, 2022, 01:22:50 pm »
What a score those are proving to be- except for the wareanty bit of course.
Those ---daisies---!
I have one of those chassis with vertical collapse too.
Let me know what you do to fix it and maybe I can learn something useful this month!
« Reply #20 on: August 13, 2022, 06:30:30 pm »
vertical collapse...either the TDA chip or the resistor feeding power into it has gone open or out of spec... or both. (usually the vert chip fails, goes shorted output and overloads the resistor, blowing it open.
« Reply #21 on: August 13, 2022, 06:45:57 pm »
Vertical collapse is one of those failures you are kind of glad to see.
Straight forward problem.
Now I have a D7700 with a bad flyback.
Is there a source for those?
« Reply #22 on: August 13, 2022, 08:05:32 pm »
I tested all of the monitors.
out of 16...
1 has vertical collapse
1 has a bad flyback
1 works fine, but has a chewed up anode wire. It needs to be replaced.
3 of them have tube burn that I consider bad. They will need tube swaps.
Not bad for 200 bucks.
bobbyb13
« Reply #23 on: August 13, 2022, 08:41:59 pm »
With all those good spares it sounds like you should be building something!
I really wish I knew where to begin with fixing chassis.
I know what lilshawn said was english and useful but it may as well have been written in cantonese.
« Reply #24 on: August 13, 2022, 09:30:36 pm »
Hehe.
We all start somewhere.
lilshawn knows a lot more than I do.
I am just removed the anode cup and I am going to pull the chassis and throw it on my bench.
  • Last login:March 14, 2026, 08:11:32 pm
« Reply #25 on: August 13, 2022, 09:33:58 pm »
Bad ass.  Hook up your Saturn - it has native RGB.
« Reply #26 on: August 13, 2022, 09:39:08 pm »
I already do that.
I have it hooked up to an arcade monitor.
I also have it hooked up to a JAMMA adapter I built so I can play it in my JAMMA cab.
« Reply #27 on: August 13, 2022, 09:43:04 pm »
Pic from 2020
« Reply #28 on: August 13, 2022, 09:46:00 pm »
Saturn on my candy cab
Zebidee
« Reply #29 on: August 13, 2022, 09:49:01 pm »
Hehe.
How do you remove/replace the anode cup?
This is something I've wondered about as I have at least one flyback (for a TV) that seem OK but needs a new anode cup.
« Reply #30 on: August 13, 2022, 09:56:30 pm »
Misunderstanding.
I removed the anode from the tube so I can work on the chassis.
But, I do have one monitor that has a chewed up anode cup.
Arroyo said he has replaced the anode wire and cup on a flyback with a donor from a television.
He is going to show me how to do that when he comes out here in October.
Zebidee
« Reply #31 on: August 13, 2022, 10:33:39 pm »
Ah ok, sorry and thanks :D
Maybe, if you remember at the time, taking some pics and posting would be appreciated   :notworthy:
buttersoft
« Reply #32 on: August 14, 2022, 01:07:20 am »
It can be done with an HV splice kit and a donor anode cup :)
bobbyb13
« Reply #33 on: August 14, 2022, 01:28:36 am »
I would figure maybe that would be possible with some good soldering and adequate heat shrink/rubber electrical tape/silicone treatment?
Zebidee
« Reply #34 on: August 14, 2022, 01:47:43 am »
Thanks butters. Have you got any links to a "HV splice kit", or can you explain how that works a bit more?
buttersoft
« Reply #35 on: August 14, 2022, 02:16:40 am »
This kind of thing...
https://www.ebay.com/itm/254887941195
I imagine a general-purpose HV splice kit would also be fine, so long as it was compact enough overall.
Zebidee
« Reply #36 on: August 14, 2022, 02:43:35 am »
Thanks. Looks like it'd do the job  :cheers:
