Main > Main Forum
Are some games too fast or am I too old?
Pages: << < (6/18) > >>
pbj:
I've found that going back to some console games that confounded me as a kid has been a much easier experience as a grizzled jackass.  Maybe I've seen it all or something, but the patterns are much easier to recognize on some of them.  There's also a lot of cheesy BS to make games artificially hard that we can cut through with a Game Genie so I can move on with life.
RandyT:
--- Quote from: pbj on August 23, 2022, 03:06:25 pm ---Maybe I've seen it all or something, but the patterns are much easier to recognize on some of them.
I'd say that you were on the money with that assessment.  There are only so many ways to skin a cat and once you have skinned a few dozen it becomes second nature (metaphorically...don't skin cats)
Xiaou2:
--- Quote from: leapinlew on August 21, 2022, 07:40:53 am ---I used to play fast Ms. Pac-man all the time when I was a kid. I never had an issue with it, or missing turns, or whatever. I will miss turns more frequently now when I play at home with a 4 way WICO leaf with little use. It was NOS a few years ago and it's still a pretty tight joystick.
I just played Ms. Pac-Man at a barcade and it had a happ anniversary stick in it. I had no issues with that stick, which was also well broke in, and felt easy to play the way I used to play when I was a kid.
So.... the hardware definitely has to be factored in.
 The original machines used a 4-way stick assembly, which is very different from the Wico.
Big Metal beast, with a rounded ball actuator, and a Short Ball-Top stick.
 Not sure how different the Diamond shape is between the two... but Id bet that the much shorter
balltop, is one of the main reasons for faster reaction times.
 Longer hand movement Distances = Longer reaction times.
negative1:
some more maxouts or near ones:
nearly maxed out galaga on practice mode 999,740
nearly maxed dig dug needed a little more dirt 999,960
maxed out pac-man at 999,990
later
-1
javeryh:
OK now I think I'm just bad at games.
Go to full version
