Author Topic: Outrun MAME  (Read 4625 times)
Krakatoa
  • Last login:April 20, 2025, 09:51:06 am
  • No idea what I am doing
Outrun MAME
« on: July 06, 2022, 07:27:30 pm »
Hi,
I am not sure where to post this. I've searched the internet, but I can't find a solution. Whenever I play outrun in my cab the traffic disappears into the distance and then there isn't any more traffic. Also, the timer runs out before I can even complete the first section. Is there a setting somewhere that I have inadvertently checked when setting up my wheel?
thanks,
MotownC
  • Last login:August 19, 2025, 01:26:42 pm
  • Reliving my youth, one lap at a time
Re: Outrun MAME
« Reply #1 on: July 07, 2022, 01:08:17 pm »
Sounds like something incorrect with your gas / brakes (same axis?). Like you are only driving half speed and cars are faster than you. How is it remapped when you 'tab' into controls?
  • Last login:Today at 04:48:55 pm
Re: Outrun MAME
« Reply #2 on: July 07, 2022, 06:19:19 pm »
Sounds like the game is only getting a limited range of values because your gas pedal hasn't been calibrated and/or MAME hasn't been properly configured.
Go to Windows Control Panel -- Devices and Printers.
- Right click on the icon for your wheel/pedals -- Game Controller Settings -- Properties.
- Check if moving the wheel and pedals through the full range of physical motion moves the crosshair/slider through the full range of motion.  Calibrate if necessary.
I assume you've already read through the stickied beginners thread here and adjusted deadzone, saturation, etc.   ;D
buttersoft
  • Last login:Today at 01:11:21 am
  • Is running at 15kHz
Re: Outrun MAME
« Reply #3 on: July 07, 2022, 07:02:08 pm »
Or maybe the shifter is backward, or not mapped so you can't change from low gear to high gear?
MrThunderwing
  • Last login:February 21, 2026, 03:10:59 pm
Re: Outrun MAME
« Reply #4 on: July 09, 2022, 05:26:18 pm »
This sounds like the most culprit to me.
Krakatoa
Re: Outrun MAME
« Reply #5 on: July 14, 2022, 07:38:14 pm »
Thanks for the tips guys. Ill check the shifter now, though I thought I was driving in automatic
Krakatoa
Re: Outrun MAME
« Reply #6 on: July 14, 2022, 07:40:49 pm »
That was it lol. I was in low gear. What a knob. Thanks :)
buttersoft
Re: Outrun MAME
« Reply #7 on: July 15, 2022, 06:12:03 am »
well, i can't deny that cheered me up a bit :D
srsly tho, we've all made mistakes like that, don't sweat it :)
