Main > Buy/Sell/Trade - non-retail
WTB Williams 49 way joystick
<< < (2/2)
PL1:
--- Quote from: bobbyb13 on December 09, 2021, 07:07:13 pm ---I just need to figure out everything that you posted here and order some ICs and harness connectors!!
For the JROK 49-way connector, instead of the "molex 90123-0108 or FCI 65039-029LF" housing listed in the manual you should be able to use a Dupont 1x8 connector housing, using either pre-fab jumpers or crimping your own wires/pins.
- Do you have an assortment of Dupont housings like these and a Dupont crimper like this one?
(there are also combo kits with ratcheting crimpers, housings, male pins, and female pins)
Even if you aren't good at crimping pins, you can get pre-fab F-F, M-F, and M-M Dupont jumpers with 1x1 housings, pull off the 1x1 housing, and move the wire and pin to a 1x8 housing
You could fit your circuit on one of the small 170 point breadboards, but it would be a bit tight (minimum of 15 out of 17 rows used) and the ICs would block at least one of the screw mount holes on the solderable version.
You'll have a lot more room with 400 point boards like this combo.
If you already have a regular breadboard, there's this solderable version . . .
. . . or this 300 point version.
bobbyb13:
Thanks as always Scott.
Immensely helpful yet again.
Especially this time for all those links.
Good strippers and crimpers I have, but that kind of Dupont assortment I have been needing for a while now!
This will be fun.
I don't even think I will destroy anything in the process.
PL1:
Glad to assist.   :cheers:
--- Quote from: bobbyb13 on December 10, 2021, 05:38:24 am ---Good strippers and crimpers I have, but that kind of Dupont assortment I have been needing for a while now!
To be clear, you don't have the Dupont pins and housings but you do have the right kind of ratchet crimper jaws for Dupont pins? (i.e. not QDs)
- If the jaws aren't stepped like #3 in this image they are definitely not correct.
Even with the right tool it can be hard to get a good, clean crimp that fits into the housing.
- Unlike horseshoes, hand grenades, and atomic bombs, "close" isn't good enough for Dupont crimps.   :lol
Mike A:
Hey look at this.
Building something instead of buying it.
bobbyb13:
--- Quote from: Mike A on December 10, 2021, 07:49:46 am ---Hey look at this.
I like buildin' stuff!
Problem sometimes when I have no idea what in the hell I'm doing though.
Good thing we all have a Scott here.  :cheers:
Now if I can get time to even scratch ---my bottom--- when it's itchy maybe I can build one of these.
Navigation
[0] Message Index
[*] Previous page
Go to full version
