Author Topic: Aliens Arcade GUNS + mamehooker need help  (Read 21018 times)
Nitro0602
  • Last login:April 22, 2024, 01:42:19 pm
Re: Aliens Arcade GUNS + mamehooker need help
« Reply #40 on: September 07, 2021, 10:02:10 pm »
Also these guns are not showing up as active devices in mamehooker? Is there something I’m missing?
Hey bud! Okay I finally got the recoil to work. I ended up using 2 power supplies. How do you get mamehooker to work with other TeknoParrot games and of course mame?
Hello i've got this and i found how to command it with mamehooker
With this command in mamooker :
ghd 1 &H04B4 &H6870 8 &h02:&h01:&h01:&h00:&h00:&h00:&h00:&h00
Coil works
ghd 1 &H04B4 &H6870 8 &h03:&h0x:&h0x:&h00:&h00:&h00:&h00:&h00
Make Display works x is the number who you want to diplay
but for make it works correctly in mame game it's not so easier
For operation wolf everything work like a charm
For Operation Ghost ( teknoparrot ), everything work flawlessly ( very good game with recoil )
For T2 , coil work the first second after make a lot of small "clac"
Before i've make a circuit with an arduino and the ledwiz code , everything works like
With this hack when output stay a 1 , i jst need to make a script to make it work correctly , but with GID i don't know with it totally crazy
Is there a way to make Generic HID works correctly?
Nitro0602
« Reply #41 on: September 07, 2021, 10:23:56 pm »
I got this work with a batch script I found online. Let me know if you need it.
you need to put
GUNENABLE  1
but you also need the I/O board ( or clone ) from aliens extermination
Nitro0602
« Reply #42 on: September 11, 2021, 10:49:08 am »
Hey bud!
Is there any links to get tis working with the same Alienware guns? The software doesn’t recognize my guns at all.. thanks!
There is nothing wrong with the gun or mamehooker, the problem is the type of recoil T2 uses is most likely too quick to keep up.   I know when I hooked those up the outputs flashed so quickly that the program couldn't keep up and display it properly in the debug window.   Try using the wait function to add a delay before turning it off and that might help but if not I'm not sure if there is a way to fix the issue.
Nitro0602
« Reply #43 on: September 12, 2021, 11:20:58 am »
Sorry for all the messages bud! MH is not recognizing the guns? When I select show enabled guns nothing shows up? Can you assist me with this please?
Ok, so an important thing to know is that the Keystates in MH listens to keyboard state changes, not joystick input, and our gun is a joystick.
With that said, you can still use a remapping tool like AHK or Xpadder, i personally verified that AHK works, and it works perfectly.
So for this example i remapped the trigger of the gun to the Letter 'Y'.
Here is an example script for a game with a keystate example:
[General]
MameStart=ghd 1 &H04B4 &H6870 8 &h04:&h00:&h00:&h00:&h00:&h00:&h00:&h00
MameStop=
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
Y=nll |ghd 1 &H04B4 &H6870 2 &h02:&h01
[Output]
The mame start is for turning on the LED Strip.
Another thing to note is that this will send a single shot recoil only,
in order to get a full auto recoil you will need to create a simple script and loop it upon holding the trigger.
Just to be clear, everything i said here is covered in the MH docs, except for the remapping of the joy to key.
  • Last login:April 21, 2024, 11:59:54 pm
« Reply #44 on: September 12, 2021, 03:09:43 pm »
I'm not sure what you mean by "nothing is showing up"   If you mean the guns aren't listed in mamehooker with supported devices that's because they aren't supported devices.   Foxhole is using the generic HID commands to control the guns... it's basically a glorified serial write and thus mamehooker has no clue what is going on.   If you use the commands he has listed it should work.   As he said, all the things you need to do in order to get things working are covered in the docs on the website.   I'm sorry but as I don't personally have one of these guns I can't help any more than that.
Nitro0602
« Reply #45 on: September 14, 2021, 12:33:05 am »
understood thanks! I am trying to make the trigger button to the letter "y" but sure how to program this in AHK?  I normally use Joy2key but mame still recognizes it as a joystick.  This is what I have so for compiled in AHK but still doesn't work: both mame and joy2key read the gun as Joystick 4 and trigger as button 1.
AHK Script:
Joy4::Send {y}  ; Have button #1 send the letter "y" keystroke.
Nitro0602
« Reply #46 on: September 14, 2021, 10:15:12 pm »
UPDATE: Sept. 23 2021
It was not working on windows 7, the settings below only worked on windows 10! dammit! Spent days trying to figure this out! lol Hopefully there is a way to work with windows 7.
Okay, normally I am decent at this stuff.. but this thing is driving me nuts! I have attached screenshots to show you guys what I have done, maybe I am missing something:
Mamehooker always shows 0 under outputs, even when I put a default gun recoil for device 1 or if I go to the specific rom eg Terminator 2..
I go under Script Editor, edit INI for Current ROM, I am using Term2 for now.  The the txt file opens up and then I select Left_Gun_Recoil= followed by Add, then select Command, select Generic HID send data.. maybe I am selecting the wrong data input?  Any help would be great!  Files attached.. once I open the rom MH always shows the output as 0.
update:
I tried the same thing with my Xbox 360 controller on the Xbox input and everything worked great! my guns recoil with Alien Extermination so I know they recoil correctly.
I have tried both inputs that Foxhole and Bandicoot have listed, but with no success.
Last image is showing the IDs that have been mentioned in this thread.. still when I press test.. nothing.. Am I doing something wrong?
« Last Edit: September 23, 2021, 02:02:23 am by Nitro0602 »
Nitro0602
« Reply #47 on: September 23, 2021, 02:00:23 am »
Hey! Okay I got it to work, but only on windows 10.. It wasn't working on windows 7 with those guns.  Is there any other settings I can use to get it to work on windows 7? I understand you do not have these guns.. but wanted to know if there was any additional settings I could use?  Thanks! I really rather use windows 7 if possible.
Foxhole
  • Last login:April 11, 2024, 04:05:15 am
« Reply #48 on: September 25, 2021, 01:02:50 pm »
Ok, i just tested the gun on my win 7 cab, and i get the same results as nitro, mamehooker commands aren't working on it for some reason. Tried playing around with the ghd command, changing report length, device index and etc, but no go. Also tried running mamehooker as admin, but made no difference.
On win 10 it works perfectly without any fuss.
« Reply #49 on: September 26, 2021, 10:00:26 pm »
Any issues you have most likely have more to do with the guns or "fixes" to the OS from updates than mamehooker.   I started development in xp a million years ago so everything worked as I migrated to 7 and then 10.   That being said I don't support old operating systems..... win 10 doesn't require any more resources to run than 7 and it's a far superior OS..... might be time to upgrade.
Foxhole
« Reply #50 on: September 27, 2021, 09:07:11 am »
I assumed the same about the updates possibly causing this issue on win 7.
I should be getting a usb2gun soon for my crt cab, as far as i know it also uses the ghd command for recoil and flash length, so if the issue is in fact coming from some update it will probably cause the same issue with this.
In that case, it's either win 10 or "play" "find the offensive update".
Nitro0602
« Reply #51 on: September 29, 2021, 09:56:59 am »
Ok good! I’m not the only one then lol! Windows 10 it is!
Also how do I setup Teknoparrot or PC games to rumble with this? Lastly a generic recoil or mame eg Jurassic Park MH doesn’t recognize any recoil for that mame game.. so I wanted to add a generic recoil to that.
bandicoot
  • Last login:April 21, 2024, 05:42:32 am
« Reply #52 on: October 04, 2021, 02:25:19 pm »
In Sega Goldun Gun for example , there's an output for Digit Display ( Number of Ball )
in mamehooker we see at startup 12 and it decrease when we shoot 11 , 10 etc
the command line for make Digit works is this
ghd 1 &H04B4 &H6870 3 &h03:&h0X:&h0Y ( X is the first Digit , Y the second )
if i use this command
ghd 1 &H04B4 &H6870 3 &h03:&h0%s%:&h0%s% , the two digit display same thing ( only the last number from outputs )
I think i don't use correct command :)
Perhaps we need to separate the number for output ? i don't know
If someone have an idea  ;)
« Last Edit: October 04, 2021, 03:10:21 pm by bandicoot »
Nitro0602
« Reply #53 on: October 04, 2021, 03:45:24 pm »
Thanks! I’ll try it out. How do you add Teknoparrot to MH or other PC games like Fright Fear Land for example.
bandicoot
« Reply #54 on: October 05, 2021, 02:18:53 am »
Use demulshooter to enable outputs in all teknoparrot game
you to need launch it by a command line with correct game selected , and launch it in teknoparrot after
You can make a Batch file like this
@echo on
cd "D:\DemulShooter"
START DemulShooter.exe -target=lindbergh -rom=rambo
cd "D:\Hyperspin Rocketlauncher\Hyperspin\Emulators\TeknoParrot"
START TeknoParrotUi.exe --profile=Rambo.xml
exit
Nitro0602
« Reply #55 on: February 02, 2022, 11:36:18 pm »
Hey guys,
I know its been some time.  I have finally programmed my guns and both work perfect.  But for the life of me I cannot get MH to work with mame.  I have input the folders and exe files correctly, but it always shows blank in MH.  I'm kicking myself as I had this working months back, now nothing works? Am I missing something? Picture attached below:
Nitro0602
« Reply #56 on: February 03, 2022, 12:07:45 am »
a little progress... but it doesn't look like it reading the rom/path?
I get an error if I try to edit the parent rom: "Mame path isn't setup properly so we don't know the parent name"
« Last Edit: February 03, 2022, 12:35:07 am by Nitro0602 »
Nitro0602
« Reply #57 on: February 04, 2022, 03:24:29 am »
Fixed it! I totally forgot about the mame ini file and adding the following:
Mame.ini
# OSD OUTPUT OPTIONS
output windows
fjser
  • Last login:March 07, 2024, 01:42:51 pm
« Reply #58 on: May 06, 2022, 11:38:13 am »
Hi All - I am in process of setting up my pair of guns with mamehooker.  So far, i have the commands for led strip, feedback, and changing display number.  Two quick questions:
1) I cant seem to find a command for disabling/resetting the numeric display.  When existing a game it shows the same number that was last o it. Anyone figure this out?
2) Any other commands I am missing?
POPO69
  • Last login:January 01, 2024, 06:15:39 pm
« Reply #59 on: May 13, 2022, 03:08:25 pm »
Hello I have problem with Haunted Museum 2.
The FFB is disable. How can I active it?
Mamehooker see game feverland....I have the Ini in the mamehooker...but no FFB. Please help
Boomslang
« Reply #60 on: May 21, 2022, 04:52:49 pm »
Hi guys,
Xx_Strike_xX has couple of these guns and sent me a message asking how to get recoil working with games which doesn't pulse value for recoil etc
so for TeknoParrot games etc ive added a small change for Output Blaster now inside OutputBlaster.ini will be a AutoRecoilPulse=0, if you change this to 1 then recoil will pulse the value on and off to allow recoil to function, adjust the Sleep= for how quickly value will pulse.
He said 25 was spot on for Sleep Value.
Maybe it helps some people,
bandicoot
« Reply #61 on: May 22, 2022, 04:21:43 am »
Big Thanks Boomslang
Nitro0602
« Reply #62 on: May 31, 2022, 03:27:06 am »
This is awesome! Is there a tutorial to get this working on TeknoParrot? I shared some files for mame games like Zombie Raid.. but not sure how to add this on TeknoParrot.. thx!
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« Reply #63 on: August 09, 2022, 01:22:22 pm »
Thanks all for sharing this useful info, and of course Howard, Boomslang and Argonlefou! I had to use my guns on my Win10 PC instead of my Win7 PC but it was worth it as the recoil definitely improves the arcade experience.
« Last Edit: August 19, 2022, 12:37:11 pm by codeena »
Nitro0602
« Reply #64 on: September 04, 2022, 11:10:01 pm »
Hey long time! Can someone let me know how to setup teknoparrot and other games like Haunted Museum etc on MH? Have no idea where to start 😂
ginzu
  • Last login:May 03, 2023, 06:51:54 am
« Reply #65 on: September 15, 2022, 10:21:23 am »
Hello friends!
As Nitro , I would like to know how to setup Mamehooker with Teknoparrot . Thank You!   :notworthy:
If seomeone can explain that on easy steps, it  would be awesome!
- i already had downloaded Mamehooker 5.1, Demulshooter 10.7.8 (i already configured output on it)
- I know  i must start Mamehookerwith admin rights but the most important questions remains : how can i connect demulshooter and Mamehooker.... And  where  could i find those games.ini ( and the one for recents games like TS and AA on TP .
EDIT Sept 16 2022 :
I tried to make it to work with My MAME emulator which is Arcade64.
But i have the following issues : Can someone give me a hand please ?  (FYI : my Mame.ini is ok  and i launch Mamehooker with admin rights. I got the inis from bandicooot i found  on another forum. (thank you @bandicoot) . And i 've seen that the com port of the gun could be important too ( i use COM3 ) , how could i tell Mamehooker i am using COM3 ? and to finish i m using a Gun4Ir as the lightgun technology.
thank you!  ;)
« Last Edit: September 16, 2022, 09:45:31 am by ginzu »
ginzu
« Reply #66 on: September 16, 2022, 01:14:07 pm »
The following file was missing : Richtx32.ocx
Now  i can acces to the edit curent rom script but i don't know if the data inside my ini(s) are correct.
When i use the Systray > Show supported device : nothing appear.
how could i know what is my device ?
my current term2.ini file look like on the picture :
but it don't hook my Mame emulator.
Otherwise, i tried to play Transformer Human Alliance and i can see i have outputs take into count but the solenoid is always acting the same way wahtever the weapon i use....
ginzu
« Reply #67 on: September 19, 2022, 04:53:58 am »
Drop! I finally found.   :laugh:
And... bandicoot ini files should not be used in my case.
bandicoot
« Reply #68 on: September 20, 2022, 01:55:49 am »
if i remember in my ini files , term2.ini is buggy but i correct it , just forgot to upload
you say finally you don't use my ini files , could you explain?
lowgunn
  • Last login:November 18, 2022, 12:01:59 pm
« Reply #69 on: October 21, 2022, 02:17:43 pm »
Do you guys recommend ay Ali Express shop selling these guns? thanks
