Main > Monitor/Video Forum
k7000 19" screwy color behavior
MKFan4Life:
I'm gonna go crazy. This is not the first time I've typed in a long reply and the board auto-logged me out, tossing the message content I had typed. Does anyone here know the length of time it takes to be logged out? I forgot to copy and paste my message into notepad, as I usually do in just this case. Sometimes hitting back on the browser restores the text, but not always. ARGH!
In a nutshell, build a MAME cabinet! I did it, loved it, and have tons of fun with mine!!!
PL1:
--- Quote from: MKFan4Life on August 21, 2021, 01:42:13 am ---Does anyone here know the length of time it takes to be logged out?
The default setting is 60 minutes.
On the login screen, you can either change "Minutes to stay logged in:" to a larger number than 60 or click on the "Always stay logged in:" checkbox.
snappleman:
I'm in NYC so space for multiple cabs is at a high premium, I already have a vertical cab for shooters (that's currently on life support due to a shorted yoke damaging the chassis), so the best I can do is a TV to run mame and all my consoles, and this TV I'm using is not RGB moddable, but it's aparently perfect donor tube for a K7000 so I figured I'd give it a shot.
MKFan4Life:
--- Quote from: PL1 on August 21, 2021, 03:21:24 am ---
Thanks so much! This has happened to me on other forums, too, not only because I need to shorten my replies, but because I am doing multiple things at once often, and sometimes step away near the end of a reply and come back to finish the post. Usually, if I have a long reply, I just copy and paste it into notepad, not only in case the board somehow tosses the reply, but you might lose power at home, or your laptop dies.
Appreciate it man!
MKFan4Life:
--- Quote from: snappleman on August 21, 2021, 03:42:29 pm ---
I see your problem living in NY. You have to make adjustments to be in this hobby at all with limited space.
Make sure you don't toss that tv tube, since it could be used for several monitor chassis models. If you don't have to buy an entire monitor, or ship more than a chassis, you have a problem licked already. I'd personally stick with an arcade monitor for nostalgia/authenticity reasons, but you have to do what works for you in your situation.
I got lucky with those capacitors I ordered to replace the shorted C44 from my K7000, as they arrived super-fast on Saturday. You know I said I had capped the monitor with a kit from Arcade Parts & Repair, replaced the shorted HOT & shorted voltage regulator. Then I installed the new C44 after having a day or so to go over the entire chassis, reflowing, cleaning flux, and testing everything I could think of, including diodes, resistors, coils, etc. I felt really good about the work I had done. The HOT and VR and the new cap all tested fine back in the board.
Well, while I had been waiting on the cap (& a new tube of heatsink compound), I examined a different K7000 chassis I had stored away about 8-10 years ago, because it really could use a cap kit, and I preferred the original from my MK1 which has adjustments on a remote board. Everything on it looked ok (except aging caps), so I installed it into the MK1 cab to verify it still worked in case I needed it. It worked just fine. That confirmed everything in the cabinet was working well, and I played it for an hour, adjusting it to the tube.
Then tonight, I put the original chassis I just recapped & did the repair work on back in and fired it up in the dark so I could see flashes of disaster. The main 2A SB chassis fuse immediately bit the dust once again. The cabinet fuse did not blow as it had the first time this chassis went out recently and the game was playing blind again.
I was able to test the HOT, VR, & C44 with the chassis installed, and the HOT & VR tested shorted, but C44 was fine. Now I need to pull it and double-check all my work... no that's triple-check, as I double-checked everything before. But I have missed something. I'm thinking it's that flyback. It has seen only a year of occasional play from time to time since it was in operation, but it was a few years back that I bought it from Bob Roberts. Also, I was adjusting either the Screen or Focus pot when the chassis took out both it's fuse and the cab's main fuse that night.
I'm going to start a thread about the chassis and see if I can get some advice. Thinking heavily about swapping the known good flyback from that other K7000 just to see if that is the culprit before ordering another.
:o
