Main > Monitor/Video Forum
WG K7191 issues
Pages: << < (3/3)
retrocat:
--- Quote from: Zebidee on March 27, 2021, 02:12:09 am ---Well done!
Check pots (vertical of course). May as well check your B+, as you've changed that voltage regulator. Also check voltage to your vertical deflection IC. If it is wrong then you might have a failed or failing support components (resistors, caps) nearby.
how do i check voltage to the vertical deflection IC?
Pages: << < (3/3)
Go to full version
