Author Topic: Sega Shifter wiring  (Read 1893 times)
Retro77
  • Last login:September 29, 2023, 08:50:10 am
Sega Shifter wiring
« on: February 15, 2021, 01:43:12 pm »
Hi all,
I thought I would just check before starting. Is the RetroRepair microcontroller method for wiring still the best approach for connecting 3 switch shifters to PC?
Also, could someone provide the correct method. The thread below (right at bottom) has 2 different pinouts. I'm not sure which one is correct.
http://forum.arcadecontrols.com/index.php?topic=106709.0
  • Last login:Yesterday at 09:41:01 pm
Re: Sega Shifter wiring
« Reply #1 on: February 15, 2021, 02:27:32 pm »
Check out baritonomarchetto's thread for several better approaches that also add a switch for "neutral".
- If you don't have a switch for neutral, one output is always active ==> one button is always pushed.
- That causes problems when trying to map other controls.
http://forum.arcadecontrols.com/index.php/topic,164398.0.html
If you want to use a 74LS138 demux, use this pinout/truth table.
- You only need to connect switch 1 or switch 2, not both since they are always in the same state.
- Connect ground to pins 4 and 5.  Connect 5v to pin 6.  (Enable)
http://forum.arcadecontrols.com/index.php/topic,164398.msg1731869.html#msg1731869
If you want a more simple setup, use this wiring diagram with the indicated changes.
If you want to add a "Neutral" switch and LED indicator to the wiring-only diagram, insert an SPDT switch between ground and switch 3 "IN". (COM)
- SPDT COM to ground.
- SPDT NC to switch 3 "IN".
- SPDT NO to LED, current limiting resistor, and 5v.
« Last Edit: February 15, 2021, 02:38:09 pm by PL1 »
Retro77
« Reply #2 on: February 15, 2021, 06:19:10 pm »
Thanks again for the help, Scott.
I was going to use the 74LS138 demux following the diagram posted by Badmouth (I think).
Is there a different wiring diagram using only switches 1 and 3? Also, would the wiring in the shifter need to be changed?
I was going to use some spare ports on an A-Pac instead of the I-Pac on the drawing. I was going to pull the 5v from a PacDrive.
Edit: I DID IT!!!!!  :)
Now I need to work out how to sync up the VR buttons with Daytona
Cheers all
« Last Edit: February 15, 2021, 07:19:06 pm by Retro77 »
« Reply #3 on: February 15, 2021, 08:29:39 pm »
The problem with that version (shown below) is that there is no "neutral" option with that setup.  One output is always low (button pressed) unless you add a "neutral" rocker/toggle/slide switch for the 5v going to pin 6.
-  When the switch is open, there is no 5v on pin 6 (Input E3 = low) ==> line 3 of the truth table, all outputs are high. (buttons not pressed)
If you're asking if there is a wiring-only (no 74LS138) version that uses only switches 1 and 3, then the answer is no.
If you're asking if there is a wiring diagram for baritonomarchetto's 74LS138 truth table (above) like this one Badmouth posted, neither baritonomarchetto nor I made one.
- You would use the same connections for pins 4, 5, 6, 8, and 16.
- The difference is the inputs on pins 1, 2, and 3 and the outputs on pins 7, 9, 10, and 11 (instead of 9, 10, 13, and 14) going to the encoder.
- The truth table above tells you which switch goes to which input and which output goes to which encoder input.
Sounds good.   ;D
« Last Edit: February 15, 2021, 08:35:13 pm by PL1 »
Retro77
« Reply #4 on: February 16, 2021, 09:15:07 am »
I have it working now. I connected the wires as per your drawing above. It seems to work great so far.
I haven't come across any config issues yet. But I am sure they will crop up at some point
