Author Topic: Multi game networked cabinets, dhcp or static IP?  (Read 1642 times)
jayc001
  • Last login:January 19, 2023, 06:14:55 am
« on: February 07, 2021, 01:58:23 pm »
I've finished building my second Daytona cab and I'm interested in multiplayer games particularly the newer games such as SR3, Daytona 3, Mario Kart Gp, Outrun SPDX etc. I have all the games setup for single cab but would like to hear from anyone who has multi game cabs set for 2 players how are the networked? Some guides for the games suggest dhcp and some static.
Zeosstud
  • Last login:March 22, 2024, 04:16:28 pm
Re: Multi game networked cabinets, dhcp or static IP?
« Reply #1 on: February 14, 2021, 11:02:54 pm »
For me, playing those games using Teknoparrot, I got into my home router and set us the machines I used with static dhcp..  You leave your router on DHCP but in a certain section go in and tell it for these mac addresses assign this IP, so sort of a combo of your question. For Teknoparrot honestly, I do not think the ips really matter, you go in and set a Cabinet ID of each machine, that is the thing it cares about most, I just tried to standardize which computer was ID 1, ID 2, ID 3 and ID 4 and of course they all had the IPs too, whatever makes sense to you.  If you happen to do it this way, also be sure and turn off your firewall to the computers before you play, it helps make the connections easier.
Here is a command you can put in a .bat file to easily turn off/on your firewall.. Changing off or on as desired.. I added the pause just so I knew when it ran, totally optional..
NetSh Advfirewall set allprofiles state off
pause
-Zeosstud
jayc001
« Reply #2 on: February 15, 2021, 03:28:16 am »
Thanks for the reply. I've set static IP and these two cabinets are offline and connected via a switch so firewall is off as there's no risk to them. I've got a few games set up but really struggling with Daytona 3. I've started a new thread for that.
In case anyone is interested I did try DHCP but several games required static so I went with a 192.168.1.x IP.
