Author Topic: M2 emulator leader lamp  (Read 2106 times)
simon_m74
  • Last login:January 17, 2021, 02:33:09 pm
« on: January 17, 2021, 02:33:46 pm »
Is there any way of outputting a signal that can be used for a leader lamp, on sega m2 emu, running Daytona
BigPanik
  • Last login:November 26, 2022, 06:02:58 pm
Re: M2 emulator leader lamp
« Reply #1 on: February 02, 2021, 03:13:57 pm »
Yes done with m2pac or DaytonaUSB
baritonomarchetto
  • Last login:Yesterday at 02:11:31 am
« Reply #2 on: February 03, 2021, 02:25:15 am »
To control the leader lamp you are in the need for three things:
- Howard's mamehooker (the software that gets the output states from the emulator and send them to a PC peripheral - see next)
- a peripheral to convert software lamp status outputs "to the real world" (PC parallel port or arduino if you want to go for free or super cheap respectively)
- an adeguate driver board to actually turn on and off the lamp as a function of the logic state detected.
« Last Edit: February 03, 2021, 02:27:38 am by baritonomarchetto »
gareth_iowc
  • Last login:October 04, 2022, 03:27:37 am
« Reply #3 on: March 14, 2021, 11:22:42 am »
I use Howard's mamehooker and a PAC drive to run the lamps
