Main > Monitor/Video Forum
Help decoding WG 27D9200 Series Part Numbers? Need 9202 Video Interface Board
Pages: << < (2/2)
kcorcoran:
I also notice your board is numbered 025A1527-001
Where mine is 085X0469-001
Not sure if this is just due to the production runs or if there is truly a difference in the circuit itself.
lilshawn:
those connectors you have there are "JST-XH" type connectors.
The board I have has Molex "Mini-SPOX" type connectors.
kcorcoran:
Well then I guess it wouldnt fit either of the monitor chassis I have.
kcorcoran:
So here is where i am with my d9200
Well I manually centered the yoke on my 9200 and taped it in place with a network of black tape temporarily. Sat it up and plugged it in.
No sounds, then a click, then that HV static sound, another click and a nice red, then green 'NO SIGNAL in the center of the screen.
OK well seems like I might have something. I'm going to epoxy the broken pieces of the yoke windings where it looks like they'll come loose form cracked plastic, I think I might need to rewind (strong word there) maybe re-loop some of the side wires onto the tabs since the main input yoke wire plastic holders broke and some of those wires came out from under the tabs.
I'll tack it in place with some dabs of silicone and make any yoke adjustments before slathering it in automotive RTV silicone to account for any heat potentially breaking down the silicone.
Nothing to lose at this point.
If this ends up working, I'll just need ot find another video input connector board to test my 9400... or actually test it first before installing it on the 9200 and dropping it into the machine.
lilshawn:
those yokes usually have a bunch of loose looking loops just hangin' out all over.
Pages: << < (2/2)
Go to full version
