Long night on the bench, aparently Jenn has issues...In laying out the red barron boards in preparation for the Mega Vector project. seems the aux boards are not all the same, and since they had a relatively low production that may not be easy to obtain, First I will have to go through my mess and make sure I don't have one...But I do have a Battlzone, And before you bare your fangs Scott, They ARE different, boards appear similar, however Red Baron had extra Rom, input for the joystick, and aparently the pointers to memory dont map the same...I do however believe it is possible to convert a B/Z, and once the Fluke is up, I should be able to target and loop specific bit locations...Looks as if there is another board build in my future, cross you fingers guys and wish Jenn luck.
