| Main > Project Announcements |
| Dual Project, Frankensplit. Part 1 Complete |
| << < (3/6) > >> |
| Drnick:
Could just be the angle, but looks like you are getting mighty close to the right hand edge with the buttons/joysticks, have you checked for clearances required under panel? |
| Bloviator:
--- Quote from: Drnick on September 29, 2020, 05:31:04 am ---Could just be the angle, but looks like you are getting mighty close to the right hand edge with the buttons/joysticks, have you checked for clearances required under panel? --- End quote --- Tks Drnick. It is snug but should fit, although I was planning on moving those buttons slightly to make sure I didn't have any trouble from it. I only have 1/2 inch overhang of the top panel on the sides. You can't rest your button hand palm on the top, but I am not too worried about extended 4P play. |
| zestyphresh:
With regards to the pocket holes you can just buy the plugs (assuming it's a Kreg). It's a bit more expensive than filler but they can be easily glued in place and the flush cut/sanded to remove the excess. No more work than a single application of filler, and if you're applying filler twice then probably quicker. |
| Bloviator:
--- Quote from: zestyphresh on September 30, 2020, 07:17:36 am ---With regards to the pocket holes you can just buy the plugs (assuming it's a Kreg). It's a bit more expensive than filler but they can be easily glued in place and the flush cut/sanded to remove the excess. No more work than a single application of filler, and if you're applying filler twice then probably quicker. --- End quote --- Definitely will try that next time. Tks |
| firedance:
--- Quote from: Bloviator on September 28, 2020, 05:21:39 pm --- Control Panel mock up in place. Any thoughts before I start drilling? --- End quote --- for me all the controls need moving all to the left, as the way it looks now player 1 is almost in the middle of the screen with players 2 and 3/4 squashed in to the right. what are the extra 2 buttons/holes for between players 1 and 2 ? maybe start with player 1 and player 2 more central on the panel then position players 3 and 4 to try and give as much room to everyone when all 4 players are playing. up to you as its your cabinet |
| Navigation |
| Message Index |
| Next page |
| Previous page |
