Author Topic: Question about coin mechs  (Read 1374 times)
archagon
  • Last login:June 24, 2004, 02:09:05 am
« on: February 19, 2004, 06:44:05 pm »
I heard that you can make the coin mechs work. If that's the case:
1) Can you change the coin required?
2) Normal arcade coin mechs probably connect to the actual game or CPU, right? Where would a coin mech on a MAME cabinet connect to?
kevin
  • Last login:October 24, 2004, 08:45:38 pm
Re:Question about coin mechs
« Reply #1 on: February 19, 2004, 06:56:53 pm »
1) This is handled on a game by game basis. Many games let you change the number coins by setting the DIP switches.
2) The coin mech is nothing more than a fancy switch that is only set off when the correct coin is inserted. You can simply run the wires from the switch into your keyboard encoder as you would any other button.
-Kevin
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #2 on: February 19, 2004, 06:58:05 pm »
1) If you mean 1 credit vs 2 credit vs free that is a game setting and you can normally change that in the service menu (F2).
2) The coin drop down and throw a switch that is just like any other button.  The coin mech microswitches connect to your keyboard encoder like any other button and are mapped to a key in MAME.
archagon
« Reply #3 on: February 19, 2004, 07:10:37 pm »
What I meant was, is it possible to change the coin type required (5 cents, 25 cents, etc), but I just found this thing, so question answered: http://www.happcontrols.com/index.html?http://www.amusementsplus.com/press/covertcoin.htm!
Actually, that brings me to another question. What if the cabinet I get already has a coin mech? Is it possible to replace it with that one? Also, if a cabinet has 2 coin slots, will that require 2 coin mechs? Oh, and where are the actual coins gathered?
Whew. One last thing. Where can I buy the lock used in coin doors? I'm planning to add a drawer housing my keyboard and mouse, and that kind of lock seems perfect.
Thanks. I'm new to the scene :P
Edit by moderator: fixed URL
« Last Edit: February 19, 2004, 07:19:44 pm by Peale »
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #4 on: February 19, 2004, 07:21:45 pm »
Yes, but most would need several pieces changed that would be difficult and often more costly than a new coin mech.
Yes. Coin mechs can be removed and replaced.  I use a couple Imonex coin mechs that accept tokens or quarters.  Since the coins fall down through the coin mech, they gather below the coin mech.  Most cabs have a bucket for easy removal of tokens/coins.
Bob Roberts sells coin door locks.  I believe he also sells a set for the coin door and back door that are keyed alike.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #5 on: February 19, 2004, 07:49:45 pm »
Peale also has a deal for coin door locks.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #6 on: February 19, 2004, 08:22:12 pm »
Some coin mechs can be adjusted to accept varying sizes.  Some can't.  Do you have a specific size coin you are looking to use?
SirPeale
  • Green Mountain Man
« Reply #7 on: February 19, 2004, 09:17:56 pm »
Hey, so I do!
I actually have a webpage of stuff I have for sale.  I really should post the URL sometime.
paigeoliver
  • Awesome face!
« Reply #8 on: February 20, 2004, 12:27:24 am »
You can also get coin door locks at most hardware stores, they are a standard barrel "cabinet lock", the only difference is the hardware store ones use flat keys, while the REAL ones use round keys.
Stingray
« Reply #9 on: February 20, 2004, 09:39:24 am »
Peale's locks are top notch and a real bargain. They are definitely of a higher quality than I really need, but they look & work great.
-S
« Last Edit: February 20, 2004, 09:39:47 am by Stingray »
« Reply #10 on: February 20, 2004, 12:00:39 pm »
I don't know about in the US, but on UK ebay there are *always* arcade barrel locks for sale pretty cheap.
SirPeale
« Reply #11 on: February 20, 2004, 12:29:06 pm »
There seem to be here in the US as well, but I've found that you buy the lock for say $2.39, but get charged $6.00 to ship it.  One guy will do this for either one lock or 100, same shipping price, but who's getting 100?
JustMichael
« Reply #12 on: February 20, 2004, 09:07:32 pm »
I bet Peale is getting 100...   ;)
SirPeale
« Reply #13 on: February 20, 2004, 10:05:17 pm »
Not from eBay!  I get them wholesale.
egomaniacal1
  • Last login:September 06, 2012, 09:34:33 am
« Reply #14 on: February 21, 2004, 06:46:40 pm »
Does anyone know if there are coin mechs made that accept dollar bills?
Was just thinking it would be neat to have one of those and not always have to have quarters on hand.
It's not what you know....its what you can prove!!!
mp2526
    • Miavio
« Reply #15 on: February 21, 2004, 07:37:01 pm »
It's not a coin mech per say, but rather a dollar bill acceptor.
crashwg
« Reply #16 on: February 21, 2004, 08:15:46 pm »
They are known as Bill Validators, they are hooked up in the same way as coin mechs but with a couple acceptions,  they need power, which can be taken from a pc, I think, or their own adaptor, and when a bill is inserted they send pulses instead of just one button press and you can set the ammount of pulses usualy with dip switches on the side of the validator.
Validators can often be found on ebay by the way.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
