Main > Monitor/Video Forum
Increase or Decrease the resistance of a yoke
robmoto:
Hi ,
ok i have heard your advice and looked for another solution .
But did you know about "Trafo Yoke" from Wansonic ? it seems to be an external transformer with multiple coils that you can add to adjust the load of your Yoke?
Finally I have found another way on my chassis , i lowered this Resistor before VPOS trimmer from 1500 to 360 Ohm ,so i can adjust correctly my image Position vertically.
and i moved the Red wire from right to left pin (didn't knew this ! ::) ) the image is not so wide now.
