Main > Monitor/Video Forum
CRT (Makvision) image is a large bluish blob. Dead, or repairable?
Pages: << < (8/12) > >>
Zebidee:
--- Quote from: Baldbull on February 25, 2021, 08:01:41 pm ---IT WORKED!!!!!!!
Now I just have to find this damn transistor I broke... 2SA1371-E
if only I'd have started with the tube.
Well, grantspain did say that up front (desolder blue gun pin)  ;)
I'm just happy it seems to have fixed the problem, you can never be sure. But for today, percussive repair techniques rule!  :cheers:
jennifer:
Glad it works...problem solved.
jennifer:
After some thought...I have to be of the opinion that smacking that tube with a brommhandle is not fixing it, and now that it is working the problem has been made more difficult to track down as a done out the door fix, and to isolate the short now you are looking at a mutiburst pattern generator as to have some control over the color and refind the original problem not to mention the other guns haven't been cleaned or balanced...Not everyone has a rejuvenator this is true, but if you can't find one cheap, you just ain't trying very hard, or flat out don't even want one...If I was to guess, that tube will be worse next time, and will most likely even burn the screen.
Zebidee:
Seeing as it must be silly season, how about we try hitting a CRT "home run" with a baseball bat then? Maybe that will improve things? Of course I am being ridiculous, but just continuing the hyperbole.
For giggles I decided to look up rejuvenators for sale (again, I do it occasionally). As usual, almost all listings are in the USA, and they are all ancient tech so I worry I'd spend more time fixing it than using it. Best option I could find that was close to me was in Singapore, US$297 + $134 shipping, fairly typical (LCT-910A). Chump change for some but serious money for me. Still...:
https://www.ebay.com/itm/CRT-tester-Leader-LCT-910A-Cathode-Ray-tube-tester-rejuvenator/323878499016?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3D87a407f9f94c43479b1f77dd3443b8cd%26pid%3D100290%26rk%3D1%26rkt%3D3%26sd%3D323878499016%26itm%3D323878499016%26pmt%3D0%26noa%3D1%26pg%3D2060778&_trksid=p2060778.c100290.m3507
Of course in the USA, land of milk-and-honey for arcade enthusiasts, I could maybe grab a B&K 46X for around $150 or even less. Drive around the corner to pick it up.
I've never owned a rejuvenator, but have done some research and watched some YT vids on them. Something that stands out is that while they can maybe (or maybe not) breathe new life into a tube for a few months or years they can actually damage the guns and filaments and that rejuvenation is really a "close to end-of-life" option. Still, nice to have and good for other things like diagnosis or CRT health etc.
dmckean:
Considering arcade cabinets and TVs tend to sit in one place for years at a time, moving the problem down the road a decade is basically the same thing as fixing it. For most of us at least. By the time this becomes an issue again, the tube may be ready for rejuvenation.
Go to full version
